Results 1 to 20 of 43
    Guys need your help is there anyone has idea how much is the tail light of '92 GTI lancer? Nabangga kasi akin nakaka bili kaya ng isa lang? how much po kaya surplus and brandnew?.Thanks po
    Feb 2005
    Replacement i.e 3rd party costs about 2K a piece.
    Oct 2007
    Quote Originally Posted by jason_b View Post
    bro san area ka.punta ka sa cinco aurora blvd.katabi ng ACSAT. madali hanapin dun at maganda dito kaw mismo pipili kung anung ilaw bibilhin mo..
    singkit GTi.
    daming surplus nyan bro... punta ka lang sa banawe or evangelista and you can get it at 1k at most per pair.
    Aug 2006
    Sa Evangelista marami siguradong OEM, pili ka lang ng matino at walang gasgas mga P1K isang side. Dyan ako bumili ng mabasag yung right side tail light ko. Sila na rin ang magkakabit.
    Salamat guys thanks for the tips.!
    Aug 2018
    Can't use the car coz tail light is broken. Hindi ko mapalitan yung bulb coz it's stuck sa socket due to corrosion. Tried WD40 (and something else haha) pero todo na to, was able to remove the bulb w/o breaking it but the metal base is still stuck.
    Baka kahit matanggal ko yung metal base ng bulb hindi pa rin gumana because of corrosion and contact issue?
    Whole socket na ba ang palitan? Ginagawa ba to sa neighborhood autoshop or do I need to source the socket and have it done sa banawe or rey's electrical?
    Thanks po sa sasagot.
    you can pull out what remains of the metal base, using long nose pliers. then fix up the socket to remove oxidized material. it should work afterwards.
    or you can buy a replacement socket from the auto parts store. you can ask the tambay mekanikos there, to replace it for you.
    Aug 2018
    I have tried pulling it out with long nose nadeform lang yung metal but no luck.
    Try ko pa ulit pag ayaw pa rin papalitan ko na. Thanks doc.
    it's a bayonet mount.
    you really have to deform it horribly, to get it out.
    PUSH mo muna LM bago mo twist, then pull
    WD40 ulit, pero this time let it soak muna
    Nov 2011
    Just replace it, make sure it's Stanley.
    It's cheap, just replace it with a new socket.
    Pero fix the issue first bakit Kinalawang, pinapasukan ba ng tubig yan tail light mo?
    Aug 2018
    Quote Originally Posted by sirkosero View Post
    Agree. Let it soak, then push, twist, pull.
    I hope ganun muna ginawa mo nung tinanggal mo yung bulb. May kilala ako hinila lang... Ganyan naging result
    Sent from my MI MAX 2 using Tapatalk
    Yup, napalitan ko na yung kabila nito few months back. Kaso hindi talaga gumagalaw dahil dumikit na yung sides sa socket. Pinush ko lang ng screw driver kaya humiwalay pero yung ilalim niya dikit pa din. Tiningnan ko mabuti, yung glass bottom ng bulb andun, so kelangan ko durugin yun para mahila ko yung metal base eh malamang sa kapipilit ko mahihila din buong socket so di bale na, palitan na lang.
    Yup, I just didn't know where to go but will try sa malapit na auto shop.
    May crack na kasi kaya pinasukan ng tubig. Palitan ko na din but for now gusto mo muna magkailaw yung tail light di ko magamit commute tuloy ako 2 days na.
    May 2018
    That's very responsible of you. Good!
    LM wag ka bumili sa tabing auto shop na di kakasya ha. make sure na kasya sya, madalas sa "typical" auto shop yun di naman talaga sakto dyan. mas maigi pa na gawan ng paraan ang corrosion dun sa existing. sayang kakatapon ko lang ng mga unused hoarded items ko, meron sana ako nabigay sayo
    i-sukat muna sa housing, bago bilhin.
    i am not sure,
    but don't some replacement light housings already include the bulbs and sockets?
    Feb 2005
    LM, Ibig sabihin ni Ninja, sa kanya mo na lang ipagawa. Sya pa bibili ng mga parts na kailangan mo, sya na lahat mag aayos mg sira ng kotse mo. Wala ka na gagawin kundi manood kung paano nya gagawin. [emoji14]
    Dec 2009
    Hindi ba kaya ni bebe love kags?
    Turco will make it stick harder
    Check your manual..follow the bulb release instruction or do the reverse the bulb attach intruction
    Pahirapan mo pa sarili mo. Palitan mo na lang ng bagong socket. Tapos ang problena.
Need help regarding tail light...
