Results 1 to 9 of 9
    Dec 2009
    Hello bros. kotse ko lancer 97 glx (automatic transmission power everything). papasok na ako sa trabaho tonight paatras ng driveway napansin ko hirap mag atras yung right rear wheel. may malakas na tunog as if may humaharang. nakaatras naman ako from driveway to street pero when i put it in drive 'D' ayaw na umandar yung gulong. pinarada ko na lang kasi baka maging worse lang ang problem. ano kaya ang problem and possible solution na dapat kong gawin sa nag lock up na gulong? thanks!
    Nov 2013
    Nilusong mo ba sa tubig tas nakahandbrake nang pinarada?
    Sent from my 3310 using Tsikot Forums🙈🙉🙊💀💩
    Two things:
    Rear brakes lock
    Wheel bearing needs replacing.
    My guess... Wheel bearing.
    Dec 2009
    salamat sa replies. never nadaan sa baha yung kotse. although napansin ko since non stop ang ulan recently basa yung loob. pa check ko sa mechanic bukas. sana matuyo na ang loob by then.
    Jun 2004
    Stuck parking brake? remove the wheel, get a hammer and try to tap it loose...
    Happened on our old car before. But again this probably won't be the recommended fix.
    Dec 2009
    Quote Originally Posted by chris_d View Post
    as a last resort i might have to do this!
    Natuklap ang brake shoe mo sir.
Need Help Pls 97 Lancer Pizza Pie Rear Wheel Locking UP
