Results 1 to 7 of 7
- Jul 2007
- 19
August 8th, 2007 06:18 AM #1my tires have uneven worn-outs on both front and back.i just have a wheel a alignment a couple of months but still the same.fluctuating voltage reading everytime i used both headlights (130/90w) and aircon.i already change my battery(9 X13 plates) my alternator is rated 90A.
recently,i have my alternator fix....my electrician wound it again and change the diode 'coz its defective...
please advice on this my fellow tsikoters...
thanks n advance....
BANNED BANNED BANNED
- 3,790
August 8th, 2007 06:37 AM #2have your wheels checked for alignment...kung aligned pa rin malamang mali ang air inflation mo.
yung electrical mo, palagay ko kulang lang sa grounding wire or palitin na ang main grounding wires mo. try to use the search function of this board/forum regaring adding grounding wires.
- Jul 2007
- 19
- Jul 2007
- 19
August 9th, 2007 11:26 PM #4my tire size is 31 x 10.5 x r15...usually what is the right tire pressure for this...
thanks in advance...
August 9th, 2007 11:56 PM #5
to be safe, 30psi is ideal for most situations, also have regular rotation of the tires so you will have even wear on all the tires. me, i rotate every time i chage my oil.
- 3,790
August 10th, 2007 03:13 AM #6yup agree with kcboy...btw kung dati ng merun pangit ng wear yung gulong minsan hindi noticeable ang improvement.
i usually put the wheel with pangit na thread wear sa likod until pumantay halos.
the culprit is usually the front
- Jul 2007
- 19
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
