Page 90 of 106 FirstFirst ... 4080868788899091929394100 ... LastLast
Results 1,781 to 1,800 of 3240
    May play ba talaga ang tensioner ng drive belt? Na notice ko kanina ng naglinis ako ng makina ng check ko firmness ng mga belts eh
    to be or not to be, that always confuses me!
    Nov 2011
    ^ meron po sa mitsuprime tabi ng monarch subd. not sure kung saan mas mura
    Dec 2013
    Nagvibrate ba steering wheel nyo kapag nadadaan sa concrete road? Pero kapag sa asphalt naman smooth and steady naman. Nacompare ko lang sa toyota company pick up na kapag nadadaan sa concrete road kahit rough yung surface wala vibration. Running at 120kph si monty wala naman vibrations.
    Quote Originally Posted by Geronimo Valino View Post
    Baka kelangan lang wheel balancing?
    Oct 2016
    Question: Pagkagaling sa pahinga ni Montero overnight then start mo sya the next day ilang seconds bago mo i start yung engine from turning on the key?
    Dec 2013
    Quote Originally Posted by typhoon View Post
    Nakapagpa wheel balancing na ako after magpalit ng gulong. Wheel aligntment never pa. 100,000 km na si monty. Either front suspension o sa steering ang suspect ko. Hindi ko pa napapacheck. Naghintay pa ako ng mga opinion at ideas.
    Sent from my LG-D620 using Tapatalk
    Nov 2011
    pagkawala ng airbag indicator
    Oct 2016
    Quote Originally Posted by silver V View Post
    Thank you po!
    100k desperately needs an alignment.
    Mechanical wear and tear are the most important. Engine lubrication and suspension checks and alignment are necessary. 400-800pesos for alignment is small change...
    Dec 2013
    Will take note of that. Thanks. Dami ko pala papacheck sa autoshop.
    May nagpapalit na ba sa inyo ng aircon belt? May kuliglig sound kase yung sakin pero d naman sobra lakas ng sound. Odo is ~18k...
    Feb 2007
    Just need belt adjustment. Too early for a replacement.
    Yup, will try that muna. Thanks.
    Oct 2016
    Para akong may naririnig na mahinang lagabog sa ilalim when I am starting my Monty. Ano kaya yun?
    Oct 2009
    Quote Originally Posted by akiramavi View Post
    Alarm systemni monty gls premium nawala.. doesnt sound anymore pag nag lock, kaso pati force entry nawala din alarm, does anyone have idea how to reset? First nagtrigger lang alarm while driving then basta na lang sya nawala..
    _/_/_/The more things are forbidden.. The more popular they become. _/_/_/
    Feb 2007
    Need to check engine supports.
    Oct 2016
    Yung display sa car info ko kung ilang kilometers pa bago maubos ang diesel lagi lang naka ganito -- paano mapapalabas na may value?
    Nov 2016
    Hi Tsikoteers,
    Currently at around 900+KMS, planning to take the 1k pms next week. Any recommended Casa po dito sa South area? I'm from Bacoor by the way. First time po mag pa PMS, any tips dos and donts? May mga na basa po kasi akong optional change oil/required/not required please enlighten me mga boss. GLS 2016
    Sep 2010
    Quote Originally Posted by EsYuBi View Post
    Hi Tsikoteers,
    I am also from Bacoor. Citimotors Las Pinas did my 1k pms. Seems ok doon.
    Nov 2016
    [QUOTE=Valsky1;2784002]I am also from Bacoor. Citimotors Las Pinas did my 1k pms. Seems ok doon.
    Sir nagpa change oil ka ba sa 1k pms? Madali lang po ba schedule doon hndi matagal waiting time? salamat sir
Montero Sport PMS Thread
