Malapit nako mag 5K PMS, ano mas OK mga master? Mag Mineral pa rin ako then sa 10K na mag FE or mag FS na this 5K?
ang 2nd value kasi ay kung ga ano siya kanipis sa specific na temp., halimbawa sa 100c na temp may viscosity na 80 ang 0-40 at ang 0-30 ay 65.... so sa normal drive na nde humahataw mas maganda ang 0-30 kasi mas walang friction..... pero pag humataw kana or karera, at long drive pa... at na abot mo ang lets say 150c na temp ng makina, ayon sa nabasa ko ang 60w 50w 40w 30w 20w ay pare parehas na ang nipis sa ganyang temperatura, ang pinag ka iba lang nila OR ang tanong ay kung kaya ba nung langis ang sustained na init ng makina....
http://www.bobistheoilguy.com/motor-oil-101/
resistance is technically friction & heat is a manifestation of resistance (fraying of pistons with the cylinder wall). consequently, the less friction, the less heat. in this case thinner oil has the advantage over thick oil
another source of heat is the one generated by the combustion process in itself which is absorbed first by the sheer volume of the engine oil of your ride. since the capacity of the engine oil is fixed then thinner oil will have the same heat absorbing capacity as a thicker oil. 6.5li of thin oil has relatively the same heat absorbing capacity as 6.5li thick oil. in this case things are pretty much even
with both things considered then thin oil is better
pls advice which dealership in metro manila allows customer to bring their oil and filter during pms?
if they really upgraded to ci4, well and good, but i am very sure stiff pa din ang pricing niyan. remember, mitsu doenst make their own oil, sinusupply lang sa kanila yan, then they just label it, presyong casa kaya mahal. dami mas maganda na oil sa presyo nila. the old turbo xp na api sm/cf was 615/liter, yung bago nila is ci4/sm, definitely mas mataas yan. now kung mas mababa, totoo kaya na nag upgrade sila? or packaging lang para bumenta. mostly kasi ng kilala ko, ayaw gumamit ng turbo xp kasi sobra daw ang pricing
You have to see the bottle. Kasi this was available nung March-April pa. Pero meron isa nag pa change-oil sa casa sa province yung old oil pa nilagay. Old stock na yun na inuubos na lang siguro. Pareho lang price e kaya nagdududa nga ako na baka repackaged lang e. Wag naman sana. Kaya dun na lang tayo sa better oils to get our money's worth.
Diamond Motors usually allow bringing customers' own oils. Basta OEM filter ang ineencourage nila if you are still under warranty.
Butchyboy, yung 15W-50 is the own recommendation of MMPC. It is in the service booklet. Dahil daw sa climate natin..
They encourage you to use Mitsubishi. Pero if you want to use Bosch or Baldwin, they will note it in your service booklet. Sa oil din ginaginawa ito when I decided to bring RP before. Depende talaga sa Service Advisor. Yung iba swabe lang sa mga ganyan they won't mind. Yung iba maingat, magsusulat sa service booklet.
