Results 1,091 to 1,100 of 3240
August 17th, 2013 01:08 PM #1091
by the way, 5w-40 is ok for our ride? kasi sa manual at booklet 15w-40 ang nakalagay e.
August 17th, 2013 03:02 PM #1092
^15w40 mineral (cheap, prone to gumming or gelling, recommended for 5thou km oil change interval)
10w40 semi-synthetic (moderately expensive, resistant to gumming allows extension of oil change to 7thou km to 8thou km)
5w40 full-synthetic (expensive, more resistant to gumming allows extension of oil change to 10thou km)
w stands for WINTER which is not applicable to the type of weather there is in a tropical climateLast edited by kisshmet; August 17th, 2013 at 03:07 PM.
- Nov 2009
- 1,756
August 17th, 2013 04:41 PM #1093
August 17th, 2013 04:50 PM #1094
- Nov 2009
- 1,756
August 17th, 2013 05:30 PM #1095
August 17th, 2013 05:51 PM #1096
i believe merong mga oil na compatible sa mga may particulate filters.
yung oil na lumulusot sa piston chamber ay sumasama sa blow by gases, that's the reason why you need to have an OCC para masalo at di magbuild-up ang sludge sa intercooler mo. intake manifold build up of sludge naman is caused mainly by the EGR.
- Nov 2009
- 1,756
August 17th, 2013 05:59 PM #1097
August 17th, 2013 06:22 PM #1098
sir noel, marami naman nagsarado na ng EGR nila. it's a matter of choice between your contribution to the environment or added performance and longevity of your ride. FS pa rin ako na oil. maaring di sapat ang occ, as i mentioned earlier you're just preventing oil going with your blow by gases to your intercooler
- Nov 2009
- 1,756
- Aug 2003
- 317
August 18th, 2013 11:42 PM #1100Pag may DPF dapat API CJ-4 ang oil. Pero wala naman DPF all variants of Montero. CI-4 pwede na.
