Page 1 of 2 12 LastLast
Results 1 to 20 of 61
    People, ano ba dapat ingatan pag nagpalit ng flat tire for Mitsu vehicles with TPMS?
    Pano ba gumaganan ito? as in nasa gulong ba mismo yung sensor? Tapos wireless binabato ang reading?
    Nasa pito ang sensor ng TPMS. And the info is transmitted wirelessly.
    sir anong wireless technology naman kaya ang gamit ng tmps? lets say you have to rotate your tires, madedetect pa rin ba niya correctly? does that mean na ang pito dapat nasa correct side (front or rear / left or right) para madetect ng tpms ng tama?
    Sep 2004
    Quote Originally Posted by louchua View Post
    i dont have tpms, but as other strada owner's mentioned, when you rotate your tires, you have to go to winterpine so they will also take out and install in the new tire position, unless, you will try to remember which is which.
    wow. hassle pala to...
    thanks for the info.
    more tips appreciated.
    Dec 2007
    Quote Originally Posted by mongaddi View Post
    mejo hassel sir lalo na pag mag rorotate ka ng gulong, pero helpful nadin kahit papano pag malambot syiya may waring ka.and every time na mag start ka ng kotse mo i checheck nya gulong mo
    Feb 2007
    Looks the same with the OEM TPMS from Winterpine sir.
    Aug 2012
    How much ang ganyang set?
    Jun 2013
    Kulang ako sir ng isang sensor at sira na ata ung front left... Makakabili kaya ng sensor lang?
    May 2017
    Reliable pa din manual checkup before ka umalis
    Jul 2012
    Quote Originally Posted by dragon05 View Post
    Agreed sir.
    Aug 2012
    Ganito yung TPMS that I mentioned in previous post. This one is for Toyota. Price is P6,950. You can get one for Mitsubishi or kaya Universal type.
    Sent from my ASUS_Z010D using Tapatalk
    Quote Originally Posted by red_one View Post
    May display ba in psi? Also, will the sensors still work with other valve caps? Ninanakaw kasi yung mga caps.
    Aug 2012
    Yes, you can set display to PSI. Yes, the sensors will work with other valve caps.
    I have a 2012 Montero Sport GTV. Nagloloko na ang TPMS wherein everytime na lang paandarin eh nag alarm siya. Mali yun nirereport na pressure sa screen.
    Meron ba way na i-disable na lang ito?
    Apr 2012
    Quote Originally Posted by jakz View Post
    same model din unit ko, ok pa nman tpms. check mo ang tamang locations ng sensors sa gulong baka nagkapalit-palit.
    Jul 2012
    Sir san kayo nakakuha nyan? naghahanap ako ng ganyan ngayon for Mitsubishi eh.
    Aug 2012
    Quote Originally Posted by turnpike View Post
    PM sent
    Ok lang ba ang TPMS na external ang sensor? As per ad sa olx, may lock naman. Costs less than 3k.
    Quote Originally Posted by b0y37 View Post
    Bought a set and using it,- okay naman...
    Malaki lang ang ulo ng "sensor"-valve cover....
Mitsubishi Tire Pressure Monitoring System
