Page 419 of 718 FirstFirst ... 319369409415416417418419420421422423429469519 ... LastLast
Results 8,361 to 8,380 of 14348
    Apr 2008
    #8361
    Mga sir alternator nga po ang problem ng fm ko. Eto nasa shop ako ngayon, luckily carbon brush lang ang problema. SAlamat po.
    #8362
    Subukan ko nga kung ok itong fuel filter. Wala kasing BF7534 sa Gigatrade kanina.
    Meron doon BD28. Nasa 880 lang ang isa. Bumili na rin ako ng BD7028 pang reserba
    Sent from my GT-N7100 using Tapatalk 2
    #8363
    Testa, magkano ang BD7028? Swak sa FM yan diba?
    #8364
    1085 yun BD7028. Oo sakto yun sa FM. Yun ang gamit ko sa 2 Pajero
    #8365
    ^magkano yung donaldson testa? Kay gigatrade mo din ba nakuha?
    Sent from my Nexus 7 using Tapatalk 2
    #8366
    Ok, meron kang tel number ng Gigatrade at address?
    #8367
    CB, oo sa kanila din. 1050 ang presyo nun fuel filter.
    Nelany, eto number 3633516 tsaka 3644876
    #8368
    Address is Rizal Ave, Caloocan. Between 3rd and 4th Ave siya going Baclaran
    #8369
    Testa, TY.
    #8370
    Initial impression ko sa fuel filter, mabigat! Parang doble ng bigat kesa sa Bosch. Made in Indonesia nga lang yun Donaldson pero feel ko yun magandang quality niya.
    Jan 2011
    #8371
    Good day guys!
    I'm looking for front bumper ends for our FM.. kahit 1 pc lang, yung right passenger side lang sana.. baka meron sa inyo nagpalit jan.. nabangga kase right side ko so pangit na yung kanan.. budget meal lang sana.. 5k/pair kase sa surplusan.. eh I only need 1, sayang pera.. either hanap ako ng 1 pc lang or repair na lang..
    Thanks!
    #8372
    Two things happened over the weekend to my FM.
    Firstly, my temperature went up. I didn't overheat but it was a bit concerning so I stopped at the nearest service station and the mechanic recommended a flush. It fixed the problem but I still am wondering about it. I just had my coolant flushed and replaced last December and I always maintain my cooling system.
    The second incident was electrical in nature. All my lights inside along with my compass, clock and stereo stopped working. I found this to be odd as well but I took it to my trusty electrical guy who told me that some fuses blew. He replaced the fuses and increased the amperage as he said the values I had were a bit too small.
    My questions are:
    How often do you have your coolant flushed and replaced?
    What values do you use for the interior fuses?
    Apr 2012
    #8373
    Quote Originally Posted by K.I.L.L. View Post
    My questions are:
    Paps, for me nag fuflush lang ako pag tumataas temp ko like you pero may nagsabi sa akin na its better to flush it at least once a year or every 18 months depende sa gamit. Mahirap na mag over heat
    for the fuses, my electrical guy always put higher value for the fuses compare dun sa stock ng pajero. See if you added or upgraded some devices na dagdag konsumo.
    Apr 2012
    #8374
    Guys,
    san meron liquid moly diesel purge aside from Power Torq in QC Congressional ? I went there 995 isang can + 250 labor for 2 cans. I thought libre na labor if I buy 2 cans. Matagal na kasi walang cleaning injectors ko pero d naman mausok ;)
    #8375
    1. Me, I replace the coolant yearly.
    2. IIRC, 15A is the value. I'm not sure though but don't replace the stock fuse to a higher value.
    #8376
    Meron ako nakita last month liquid-moly diesel purge sa Timog, Bridgestone fb ladao. Can't remember the price but I think its cheaper than P995. Tapos free ang labor. Dun kc ko nakakita ng Mos2.
    #8377
    Quote Originally Posted by PapaPaj View Post
    Guys,
    Nagtaas na ng price sa powertorq. 750 lang before tapos pag 2 cans libre na labor
    #8378
    *kill, nagbabawas ka tubig? If not, check you fans. Baka may sira na or may nagbblock ng airflow.
    My questions are:
    A. depends sa coolant if yung normal lang or pang-extended performance. Mine every 4 years of 100,000kms.
    B. Stock values din lang for me unless may changes.
    #8380
    Sa d'fort meron din nag bebenta ng Liquimoly baka mas mura dun diesel purge... Next change oil, Ceratec gagamitin ko. Nag iicip nga lang ako if Top1 SDO or ibang oil gagamitin ko... Any Ideas HM Mobil TDT ngaun?
    BTW maganda pala pag mono tone red ang Pajero noh? di ba CB?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
