Page 313 of 395 FirstFirst ... 213263303309310311312313314315316317323363 ... LastLast
Results 6,241 to 6,260 of 14348
    Reasonable na casa price. Less 20% parts pa daw. Srp yan nasa receipt. 7k daw labor. May 1 year warranty daw. Yung mahal na part diyan gear assembly worth 8k di kasama sa quote nila. Ako lang nagpadagdag. Para all parts bago na. Chain and upper and lower sprockets to last me the next 15 years.
    sabi ng mechanic hindi lang ako sure, pag 4x4 double row chain daw. 4x2 is single.
    yes that is very reasonable. if those would last for another 15 years, that's more or less Php750 a month. I just hope all casas nationwide have the same price or within the same price range.
    Sep 2014
    Mga sir baka may alam kayo radiator Shop palit sana ako brass top May leak na plastic TOP radiator ko
    Aug 2007
    Quote Originally Posted by Alani View Post
    Sir, ayaw mo ba replacement lang na radiator? Kaya lang plastic top pa rin, Nasa 8k ata kay bestcolt sa banawe. Ikakabit mo na lang...
    Sep 2014
    Quote Originally Posted by ikaw_ngaba View Post
    Pwde din. Oem kaya yung sa bestcolt?
    Aug 2007
    Replacement lang sir. May warranty naman sila binibigay
    Some of us had our radiator repaired at CoolCharge (keyser) in West Avenue, by changing the plastic top. They will check the cooling system as well. Will cost you around 10k. Workmanship is superb.
    Just a tip, technician/owner would suggest changing some parts like thermostat, radiator cap, etc., which is good for our car. If you can buy your oem parts from your suki in Banawe, much better so you can save some bucks. I noticed that some of their parts are more costly than the casa's price.
    Sep 2014
    Tnx sir. Baka meron kayo alam Rizal or Pasig area
    Quote Originally Posted by direk View Post
    Thanks sir, the car is running great. Ganda ng hatak this time at ramdam ung power. Lesser smoke as well as walang sign ng tagas sa cover or occ.
    thats good. thanks for the update
    Mar 2003
    Share ko lang parts ng timing chain, para pag kayo na mag papagawa, masasagot niyo ng maayos mga mechanic.
    6 major parts.
    = Timing chain
    = Tensioner : ito yung smallest part na nag tutulak sa tension lever
    = tension lever : yung letter c shaped
    = chain guide : yung nasa lower part color grey
    = camshaft sprocket, upper chainwheel
    = gear assembly, pump idler : lower sprocket with gear, most expensive part but optional daw according to casa.
    6 major parts.
    = Timing chain
    Nice sir PB!
    Ipapa-check ko na din nga yun sa paj.
    Nice sir PB!
    Yung symptoms ba na maingay/palitin na ang timing chain eh tunog na mapapansin mo talaga? Meaning kahit noob sa sasakyan eh manonotice nya na something is unusual?
    Running on 123k km na ako wala naman unusual ako nadidinig.. Although si PB magpapalit at around 180k km. Thank you for your inputs guys
    Quote Originally Posted by junerski View Post
    May nakita ako sa youtube on how to check a timing chain if it needs replacing or not. Yun plan ko ipakita sa suking mekaniko ko. Nakikinig namn sa inputs ko yun, hopefully tama diagnosis niya.
    Nagsasabi naman yun kapag alanganin siya which means gastos!
    But yeah, sabi nila may ingay daw na na-cre-create ang worn out plastic chain guide. Maluwang na kasi siguro. But it is best to have visual checking.
    Okay na lights! Next time LED na din fogs.
    May 2010
    ^^ Kano score mo sir? And san mo nabili?
    Quote Originally Posted by romeocharlie View Post
    Sa olx sir yung LED reverse light. Fog lights sa isang surplus shop dito sa amin. Ito key words:
    Pair BA15S P21W 1156 60W White LED Bulb for Reverse light
    Question, may replacement ba sa rubber spacers ng intercooler natin na nabibili sa mga suki natin sa Banawe?
    Mar 2003
    Junerski, Meron ka maririnig na pag nag Rev ka going to 2k rpm, imagine mo chain rubbing on metal ng mabilis. Rattle sound siya. Kahit naka stop ka and laruin mo accelerator maririnig mo siya. Di siya sobrang obvious but alam mo may new sound yung engine. More truckish sound.
    ok noted PB.. thanks. Noticeable sound naman pala.. Is it advisable to have it replaced say at the 150k km mark (as a preventive measure) rather than waiting for the rattling sound to occur.. or just maximize the life of the timing chain?
    Mar 2003
    Hindi na siguro bro, yung 4x2 ng uncle ko 2003 model 210k na tinakbo. Walang timing chain noise.
    Thats good to know.. its indeed "maintenance free" as mechanics would say as long as hindi nag iingay.
    guys, yung thread natin kahit na puro maintenance na pinag uusapan eh kahit papaano may mods pa rin tayo ginagawa sa rigs natin..
    it just shows na timeless Paj
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
