Results 10,941 to 10,950 of 14348
August 20th, 2014 01:37 PM #10941
August 20th, 2014 01:40 PM #10942
August 20th, 2014 11:08 PM #10943
pajero02, ito yung positive side ng battery going to alternator. gauge 4 then may fuse for protection. pinaikot ko sa firewall yan.
yung negative side is grounding kit lang kailangan mo. ilapit mo lang sa mga electrical. Like headlights, wiper motor, horn, engine block, fans, 4wd solenoid.
pag luma na kotse mataas na resistance ng wires kaya makakatulong to fluctuations.
August 21st, 2014 12:22 PM #10944
salamat po sa mga reply. I tried sa casa kahapon wala sila nun. para daw mag down shift agad pag sagad apak sa throttle. ill consult mr atutubo. salamat po ulit.
Posted via Tsikot Mobile App
- Aug 2009
- 420
August 21st, 2014 06:06 PM #10945Good pm sir. Mayrun kami 2006 pajero fieldmaster local edition. Pinalitan nami ng oil kanina tapos may konti leak ung sa top. So bumili kami ng valve gasket (rubber), oil ginamit aisin brand 5w40. After ng palit umuwi ako 5km ung layo. Tapos while going home wla na hatak ung pajero tapos uusok sya. Nakita ko un pagawa sa pajero ung ginawa ng mekaniko pour engine flush pinaandar for 2 to 3 mins then drain oilfilter, then tangal ung cover thenpalit gasket. Tapos binalik ung tube at wire. Nasauli lahat ung tube at wire. Pwde ba un, hindi tagalin postive sa battery kung palit valve gasket, pls help sir
- Aug 2009
- 420
August 21st, 2014 06:07 PM #10946Naglagay sya 7 liter 5w40 aisin brand. Pwde ba un na mag reset un turbo kung hindi tangalin ung postive sa battery?
August 21st, 2014 07:31 PM #10947
Yung sa leak maaari rin dahil sobra dami nung oil na nilagay, may kilala kasi ako lagi sobra nilalagay na oil nagleak valve cover niya tapos sumunod yung oilpan gasket... 6-6.5 liters lang ang capacity ng 4m40. Pero subjected rin naman sa wear and tear ang valve cover gasket
Yung pagpalit ng valve cover gasket hindi naman electrical related so disconnecting the battery while replacing it is not necessary
Although kelangan tanggalin yung intercooler... baka hindi naisoli ng maigi mga turbo hoses kaya walang hatak... pwede rin baka marumi na air filter mo or barado na fuel filter.
- Aug 2009
- 178
August 21st, 2014 07:35 PM #10948Pwede po kayang gamitin ang water temp sensor as oil temp sensor? Got an oem oil temp gauge but without the sensors po.
- Aug 2009
- 420
August 21st, 2014 10:42 PM #109497 liter palagi ko gamit sa change oil. Un nga sir baka hindi nasauli ung iba hose pero nakita ko may nahulog na something then may nakita ung technician tapos binalik nya. Maghanap pa ako same model para makita ko ung hose connection kung same ba an kabit. Tapos kung tapak mo gas may tutunog.
- Aug 2009
- 420
August 21st, 2014 10:45 PM #10950Bfor change oil at palit valve gasket ok ung hatak sa pajero fieldmaster, wlang problema
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
