Results 10,581 to 10,590 of 14348
July 7th, 2014 12:20 PM #10581
July 7th, 2014 12:37 PM #10582
Sa akin sabay and ang alam ko dapat sabay talaga and walang delay... Nagpalit na ako ng relay nyan sa Reys Electrical (Denso brand)
Usual symptoms na relay ang problema kapag sabay ayaw umandar ng big and small aux fan (assuming relatively bago/good condition mga fan) tapos yun nga, iinit ang aircon.
Ingat lang diyan maghihigh pressure yan and baka masira hoses mo kapag hindi umaandar mga fan due to faulty relay.
- Feb 2013
- 157
July 7th, 2014 12:55 PM #10583
July 7th, 2014 01:11 PM #10584
I changed all my hoses back in 2012. After one sprung a leak, the rest started leaking a few months after. All in all, there are 4 power steering hoses. Some are just hoses while others have a metal tube attached. The hoses with metal tubes are a lot more expensive. I ended up spending around P24,000+ on all the hoses but mine are all OEM. The other FM owners here have discovered a shop where it's a lot more cheaper. Just back read a few pages.
I haven't experienced that but I have changed my relay and fan motor already. I think their lifespan is five years. Don't forget that there's also a small fan at the bottom for the rear A/C. When mine stopped spinning, the rear A/C stopped getting cold.
- Nov 2011
- 28
July 7th, 2014 01:26 PM #10585
July 7th, 2014 02:39 PM #10586
- May 2008
- 60
- Aug 2009
- 178
July 7th, 2014 11:05 PM #10588Ang code alarm po ba me auto lock/arm function mga sir?
Posted via Tsikot Mobile App
- Jul 2013
- 74
July 8th, 2014 01:03 AM #10589
- Jul 2013
- 74
July 8th, 2014 01:07 AM #10590[QUOTE=K.I.L.L.;2371833]Sounds like you have a ground somewhere. You need to trace it with a competent electrician.
Binalik ko un old bulbs ko. Naging okay na ulit pati likod wala na naiiwan na isang row haha.. di ko magets bakit ayaw sa led ng dome lights ko.. try ko naman led un dome lights tapos sa likod naman un hinde kung mawawala rin
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
