Results 9,961 to 9,970 of 14348
March 19th, 2014 11:36 AM #9961
- Apr 2010
- 15
March 19th, 2014 12:08 PM #9962Mga Sir,
Ano ba need palitan sa Pajero Field Master 2005, every 5k run? and also mga need to replace for 85k run?
Bago kasi sa akin yung Pajero and Diesel maintenance. Thanks!
March 19th, 2014 12:51 PM #9963
5,000 - oil & oil filter. The oil of choice by most here is Top 1 SDO while the oil filter of choice is Baldwin.
10,000 - air filter, fuel filter
20,000 - ATF
underchassis - greasing every 6 months
Make sure your radiator is clean. You may need to flush it every so often.
I and some of the gentlemen here add 2T oil into the fuel tank when we top up. ratio is 5ml / litre.
At 85,000 - you will need to replace your water pump soon. Your power steering hoses might be brittle by now too.
Check your brakes every 20,000 and see if they need replacement.
How are your tyres? Our tyre size for stock rims is 265 / 70 r16.
Good luck!
- Apr 2010
- 15
March 20th, 2014 11:35 AM #9964Sir K.I.L.L., do you have recommended stores to purchase these parts? And also recommended Talyer or Mechanic? BTW, I'm from Cubao area.
March 21st, 2014 06:14 AM #9965
Kung kaya mo i-DIY ang basic change oil (palit filters, ATF), ikaw nalang gumawa para makatipid ka pa. Regarding sa parts, Banawe ang isang alternative mo since taga Cubao ka lang naman. Greasing, pwede na sa suking gas station basta meron silang greasing services. Same with basic change oil, pwede na rin sa gas station nalang para makatipid. Underchasis naman, alam ko may Cruven o Zee dyan sa inyo malapit at magagaling sila as per posts dito sa tsikot.
March 21st, 2014 01:22 PM #9966
I got to either Triton on Banawe or El Dorado for my spare parts. Others here go to Motorix and Mit-Parts on Banawe for their parts.
I think everyone here has a go-to guy for whatever ails their FMs. I used to take mine to speedyfix in San Juan who are very capable. However, I take mine to Joseph Atutubo over in Paranaque since he is closer. I have my oil and filters changed at a Petron service station close to my house. Greasing is done at a Shell station near my house too. A highly recommended place for electrical issues is Jemson's shop over on Banawe.
Good luck!
March 23rd, 2014 10:54 PM #9967
Guys, may naka experience na ba sainyo ng loose/unresponsive steering? Yung tipong pag mag tuturn or switch lane kailangan pang mabaliktad yung manibela para lang makalipat. Kaka checked ko lang nung power steering fluid and mataas pa naman siya. Ano kayang problem? And hindi pala siya nag wiwiggle, sobrang unresponsive lang talaga.
Thanks in advance
March 25th, 2014 09:23 AM #9968
Sumagot na si Garahe sa inquiry ko sa Tough Dog. Deym, 61k complete set ng Tough Dog for Gen 2/2.5 :um:
March 25th, 2014 09:36 AM #9969
Ironman nalang. 40k hehe
Sent from my Nexus 5 using Tsikot Forums mobile app
March 25th, 2014 09:58 AM #9970
Akala ko nga papalo lang ng 35k yun Tough Dog eh
Nag-PM na rin ako ke Monsterworx kung magkano ang Ironman nila.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
