Results 8,471 to 8,480 of 14348
- Nov 2010
- 174
September 25th, 2013 06:51 PM #8472
- Nov 2010
- 174
September 25th, 2013 09:50 PM #8473
- Sep 2013
- 6
September 26th, 2013 05:49 AM #8474Sir did you replace your torsion bars or is this still the OEM..?
September 26th, 2013 09:31 AM #8475
Normal lang basta huwag nga lang malaks ha. Tsaka kapag cold engine starting dapat wala pa, kapag wamr na engine bago dapat lalabas yan. kasi kung cold start pa lang meron an agad very noticeable na talsik, may blow-by na yan. Either ip-compression test mo to be really sure of use a heavier weight oil na 20w50 as stop gap solution. But it is not a long term solution ha. Baka kelangan na palitan piston rings kasi. have it check by a reliable mechanic if nagdududa ka.
Good sign naman na sa oil dipstick eh walang singaw.
September 27th, 2013 11:00 AM #8476
Gentlemen, have any of you replaced your radiator? How much did it cost and who did it for you?
September 27th, 2013 11:24 AM #8477
i had mine repaired before. replaced the plastic top. cost is around 6.5k.
you can try Joseph Atutubo. meron siya plastic top with aluminum core. not sure about the price.
- Sep 2013
- 2
September 27th, 2013 12:42 PM #8478Good day! Former lurker here.. meron na po ba nagpa sound deadening dito para mawala yung mga maliliit na tunog sa loob ng cabin ng paj? ano mga sir ginawa niyo para mabawasan yung mga tumutunog sa loob ng cabin? thanks
September 27th, 2013 02:13 PM #8479
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
