Page 64 of 330 FirstFirst ... 145460616263646566676874114164 ... LastLast
Results 1,261 to 1,280 of 6591
    #1261
    Yes, Mit parts sells both genuine and replacement parts. You can also try Bestcolt (malapit lang sa Mitparts). Usually cheaper sa Bestcolt.
    May 2005
    #1262
    Ilang litro ba laman ng tranny ng Pajero or Montero? Medyo nalilito kasi ako sabi sa casa 7lts. daw pero ng magdrain ako 3lts lang nakuha ko. Nasa converter kaya yong iba? Thanks
    #1263
    You need a specialized pump to drain out all the fluid.
    I don't know where in the Metro you can find one, though.
    May 2004
    #1264
    otep & larshell; alam ko autotechnika meron. parang nabasa ko dati sa 4x4ph c/o JQP.
    May 2005
    #1265
    Otep, Naisip ko kong tangalin ko yong one line ng hose going to the oil cooler tapos sahurin ko para madrain lahat ng ATF. Pwede kaya yon?
    Niwde11,May Tel# ka ng Autotechnika?Saan ba yan?
    #1266
    Commonwealth Ave. ang AUTOTECHNIKA. Almost Fairview area na ata.
    Mar 2003
    #1267
    peeps share ko lang, had my emission testing kanina. ganda ng score ko .19 lang. just calibrated my ride 2 months ago. past yearly scores were .39, .38, to 1.0 last yr yan. same testing center
    Apr 2004
    #1268
    Quote Originally Posted by larshell View Post
    ganyan din ginawa ko bro... pinatulo ko lang til naging malinis na yung atf na tumutulo (while the engine is running).
    May 2005
    #1269
    Dok Otep, Ok ba sa Autotechnika?Na try mo na ba dun?
    v22, Will try that also. Ilan litro naubos mo? Ano engine ng Pajero mo?
    May 2004
    #1270
    larshell; lagpas lang sya ng arko coming from QC circle. left side sya. kung libre ako pwede kita samahan. yung number nya malamang nasa 4x4ph.
    Apr 2004
    #1271
    4d56tdic... forgot ko na kung ilan, parang 5 or 6 ata... laki ginanda ng takbo ng paj ko afterwards, ang smooth shifting
    May 2005
    #1272
    Quote Originally Posted by niwde11 View Post
    Talaga Bro samahan moko? Next week pwede ka?
    Quote Originally Posted by v22 View Post
    Subukan ko yan. How about the strainer nilinis mo din ba? Surplus engine and tranny right?What Brand of ATF did you use? DextronIII ba?
    Apr 2004
    #1273
    diko pa nalilinis ang strainer up to now, nakakatamad :D. Surplus whole unit, Subic pajero kasi... used cheap ATF lang, RAYJAN ata yung brand, DEXRON2.. 60-70 pesos a liter.
    May 2004
    #1274
    larshell; txt mo lang ako 2 days in advance. medyo bakante ako these days dahil napostpone yung project. sorry sa OT.
    #1275
    Quote Originally Posted by badsekktor View Post
    magkano air filter ngayon ng gen 2? pareho rin ba to sa gen 2.5 na air filter?
    Local 4D56TDIC and 4M40TDIC filters and filter assemblies are the same.
    #1276
    Nasa Php300 na on the average ang replacement air filter (nagtaas na).
    #1277
    Pogi talaga ng pajero mo pajerokid!!
    Jan 2003
    #1278
    oo nga eh. 350 na yun pinakamura nakuha ko. usually 600 plus yun iba. sobrang taga. magkano na brakepads ngayon? san ba ok magpapalit nito? eh repair ng power steering?
    May 2005
    #1279
    Harmful ba sa auto tranny kung sobra yong ATF? Pa reply naman mga Pajero expert. Thanks
    Apr 2004
    #1280
    afaik its harmful to overfill the tranny with atf, kumbaga sa engine napwersa ang mga seals..
    got my airfilter at coltline, 300 lang dun.. brake pads, rico brand lang.. 500 for a set either for front or rear
