Page 275 of 660 FirstFirst ... 175225265271272273274275276277278279285325375 ... LastLast
Results 2,741 to 2,750 of 6591
    #2741
    hello ulit mga bosings! problema lang po sa aircon. lately pag sobra traffic, hirap a/c ko. or like after i drop someone off tapos park lang sa tabi at hintay (not stop-and-go condition), init ulit. otherwise, it's cool all the way. pag gabi pa nga, pinapatay pa ni misis sa lamig. what's the problem here? also, pag on or off nung rear a/c switch, meron din rise in temp muna (mga 5-10mins) before it gets back to the right temp then ok na. my setting is at #1 or #2 lang tapos nasa economy.
    sir pb, i've been asking around regarding the rear chrome bumper-with-dimple solution (ala pa reply si pk eh). meron daw sa banaue that does the euro type with lights. BUT they don't use the same bumper then cut-out the part where the light is inserted. instead, they install a totally different bumper with built in lights na. di daw same material yung chrome bumper. the originals are better daw. what do you think?
    Jul 2005
    #2742
    [IMG][/IMG]
    Ano ba tawag dito? Sira kasi power antenna ko and nung binuksan namin bungi na yung gears. Saan makakbili nito? and how much kaya?
    Apr 2006
    #2743
    Mas frequent ba ang palit mo ng fuel filter if you use biodiesel ? Thanks in advance
    Jun 2007
    #2744
    Sir PB, bad trip. Ang FM ko bumigay this morning, nasira ang timing chain and it created a hole on the cover above it. I told my mechanic, timing chain is supposed to be life-time (unlike the timing belt) and why it happened? Sabi nya, maybe ang tensioner bumigay. haay gasto na naman. Any suggestions which shop should I go? which is reasonable in terms of cost? thanks in advance
    Mar 2003
    #2745
    stadaenko, aux fan lang sisguro yan bro, sirain talaga yan. may pic si jru120 niyan a few pages back.
    landlord, no idea ako about biodiesel,
    garci, medyo familiar narin ako diyan, ilang beses ko na kinalas yan, you have to remove the motor para maikot mo yung center gear. medyo mahirap lang ibalik dahil sa carbon brush, bali ba yung antenna mast (long white plastic with ipin)? nung nagsawa ako kakaremedyo, my remedyo only last a 2 to 3 months, kaya binili ko oem mast na, 2,100 yata dati. 3 yrs ago na. sabi nila sa banawe daw merong 500 lang na replacement. hindi ko lag sure kung saan meron.
    andrewbugs, sobrang bad news nga niyan bro. in theory dapat mas tatagal pa yan sa buhay ng engine. paano daw yan overhaul ba daw? any signs bago nangyari yan? kung tensioner dapat maririnig mo na maingay yung chain. share naman info bro, cost and scope of damage? may nagbukas na ba ng cover ng timing chain mo dati? baka may nagalaw. keep us posted nakaktakot mangyari yan, malalaman naman ng mechanic kung bakit nasira yan,
    Aug 2005
    #2746
    Docholiday,
    I own a 4x4 FM. I acquired it last Sept 2006 (3rd owner na ako; got it 78K mileage) and very satisfied sa performance nya. Sulit na sulit I would say. Several trips to Baguio with 8 people, Batangas, Laguna, Quezon and Subic A. No major repairs so far, alaga ko lang sa change oil and filters. nag change pa lang ako ng 2 tires and brake pads and now nasa 109K mileage.
    I believe it was also well maintained by the first previous owner kasi hanngang likod ng service manual may tatak ng casa.
    Very useful ang 4x4 specially pag sa salunga, wet roads and mabigat load.
    Depende sa purpose ng vehicle for you, ako kasi I usually go out of town with my family. And like this moment gamit sya ng daughter ko with her classmates sa nasugbu.
    good Luck sa search mo. Ako, it took more than a year kasi on and off di mag timing pera at available na unit. One day I decided to get a loan and I got the unit at a good price since the owner need to dispose his FM dahil na short sya sa construction ng house nya.
    Jan 2003
    #2747
    guys, baka may idea kayo kung magkano yun bearing ng compressor? may leak yun compressor ko and yun bearing yun culprit? saka about sa turbo? paano mo malalaman na sira na ang turbo? magkano ba brandnew saka surplus? hmmm... di ko kasi nasasagad yun sasakyan kaya di ko pansin kung sira ba ang turbo o hindi
    Mar 2003
    #2748
    badsektor, pag sira turbo mausok siya and walang power. bearing no idea pa ako, but dati sa gen 2 pajero namin, bigla nalang sumingaw yung freon sa compressor, palit na bnew. di na kami binigyan ng option na irepair pa.
    #2749
    mga gurus good day to all,help nmn sa pejero fm ko ngbiblink yung front 2 wheels dun sa my dashboard khit naka 2rear wheel drive lng ako.pg kinabit ko 4wd ok nmn stop ang blink ,pag binalik ko 2 wheel, blink nanaman dapat mamamatay yun db.minsan nmn d cya ng biblink then bigla nanama mgbilblink.whats the problem kya.one more thing pano nga pala malalaman kung gumagana turbo.kass one time i notice yung fan sa ilalim ng intercooler d umiikot,so nirekta ko cya to test kung gumagana.d pa rin umiikot pero nung pinaikot ko sa finger ko umikot cya ganun b talaga yun?kailangan b ng help para umikot yun?yung air b na pumapasok sa hoodscope ang tumutulong mgpaikot nun?thanks
    Jan 2003
    #2750
    hindi pa naman mausok hehehe.... siguro naninibago lang ako dahil nag-switch ako sa biodiesel.... saka hinay sa gas pedal, mahal ng diesel...
    yun compressor kasi bro sayang kung ok pa eh. yun isa kasing pajero ganun nakailang palit ng compressor di rin nakuha yun lamig nito.... sabi ko nga baka yun tubo ang diperensya, baka napipi kaya nahirapan kahit ilan palit na ng compressor, evaporator, condenser...
    yun ngayon kasi bro 3 yrs na di nililinis, sobrang lamig pa rin, kaya lang pinalinis kasi tumulo sa loob yun tubig. kaso nung nilinis naman eto na nga nangyari... may parang konting tagas ng oil dun kasi sa may clutch nung compressor pero papacheck ko na rin buo.... baka naman hindi kasi dun ang diperensya.
    by the way bro chineck ko ulit yun tail light... same lang pala ang fieldmaster saka sa gen 2.... yun isa crystal lang pero walang LED.... yun trims nito eh chrome.... yun naman isang red and clear na black trims eh built in yun LED sa taillight.... mas maganda ito IMO. yun nga lang di ko tinatanong ang presyo. kung bibili ka dun, bilhin mo na lang, mahal kasi labor nila dun, sayang din 500, madali naman ikabit yun tail light assembly
    Quote Originally Posted by fcuyugan_29 View Post
    about sa lights na blinking, meron resident pajero expert dito na mas nakakaalam pero AFAIK, pwede yun solenoid mismo nung switch dun sa may transmission ang diperensya or pwedeng stock up yun mismomg 4wd ng pajero... malalaman mo naman eh kasi kapag stock up, medyo mabigat ang pag-turn nya saka wala yun engage/disengage sound pag shift mo from 4-2wd or vice versa.....
    about sa turbo bro, iba yun turbo sa sinasabi mo, intercooler yan nung turbo and intercooler fan yun nasa ilalim nung intercooler na parang radiator na located mismo sa ilalim ng hood scoop, actually hindi ko pa rin nasusubukan kung gumagana ba yun maliban na lang kung i-rerekta mo yun fan sa source. ang problema kasi alam ko may switch yun fan na yun so most probably, umaandar yun sasakyan bago mag-on yun switch nun.
    sa turbo bro medyo di kita matutulungan since 90 lang topspeed ko... medyo mabagal talaga ako magmaneho eh.....
