Results 1,151 to 1,160 of 6591
Tsikot Member Rank 4
- Jan 2003
- 2,979
May 10th, 2006 11:38 AM #1151i actually told him to check his tranny... we checked the and its almost below the line so i suggested that he should change the fluid..
About sa squeaking sound sa may front drivers seat.... check nyo alugin yun rig nyo. baka sa bushing dun sa may torsion bar yun diperensya
- Jan 2003
- 62
May 10th, 2006 02:15 PM #1153Originally Posted by rion
oops, di ko agad nasubmit, hehe..
- Jun 2004
- 476
May 10th, 2006 10:26 PM #1155Originally Posted by nugundam93
- Jun 2004
- 476
May 10th, 2006 10:38 PM #1157No problem nugundam93. Just wanted to clear things up as well to avoid confusion.
Larshell, drop me a PM or an email (paj4x41989*yahoo.com) if you're interested in acquiring Rancho dampers. I can get a good deal for you over here in Bangkok.
May 11th, 2006 12:02 AM #1158
Originally Posted by carnovice
others call it "trans throttle cable" others say "Transmission cable"
The kickdown cable is used to regulate a pressure in transmission valve body. This is called throttle pressure.
The throttle pressure is effectively a pressure that "tells" shift valves in transmission how hard you pushing throttle and these shift valves now have a contest to see if governor pressure or throttle pressure is going to win. This pressure is also used to apply the clutches/brakes that engage a gear and the higher pressure goes along with higher engine power at higher throttle. Firmer shifts are a result of higher throttle pressure.
If throttle pressure wins the contest the trans remains in lower gear, if governor pressure wins the trans upshifts.
Governor pressure is directly related to driveshaft, and thus road speed.
If you tighten cable you increase throttle pressure and the whole shift point/road speed "map" goes higher.
If you loosen cable the shift point map moves lower.
The trans throttle cable (kickdown cable) also depresses a valve if you (or the throttle spool) pull the cable all the way out past that hard spot which is a detent to make you aware of the actual kickdown feature.
The kickdown valve increases the throttle pressure drastically above the linear rate that you get from the rest of the throttle pedal travel range and makes the gearbox goes to lowest possible gear allowed at the road speed you are at when you activate it.
- Jan 2003
- 62
May 11th, 2006 10:20 AM #1159Originally Posted by rion
..can any mechanic check that or casa equipment lang?
May 11th, 2006 10:28 PM #1160
I only apply this method if problem is the "late upshift". but if the issue is kung tama ba ang shifting like "if it's too late or too early", then I don't know how to solve that... hehe...
If I step the accelerator pedal quickly (jack rabbit style), I go downshift and get high rpm quickly, yet not impressed with the speed acceleration... this is where I loosen it a bit. downshift will occur at 90% of pushing pedal to full. level adjustment depends on each vehicles...
some peeps may say it's normal, and it's probably is. but I really don't like it. I prefer, smoother ride even I jack rabbit style my pedal...
other thing I apply:
If I step the accelerator pedal progressively, yet 1st to 2nd to 3rd shift are late. this is where I check the Fuel Injection.
like what the "kickdown cable" is doing, if you are pushing pedal deeper, kickdown cable might downshift. but if your Fuel Injection gives enough power, you don't need to push pedal deeper, so kickdown won't be able to downshift your gear.
it's like you are setting the timing for your "automatic overdrive"...
there are still factors for late upshifts like atf, electronic, gearbox and tranny itself.
regards to badsekktor's friend. if it was an old diesel engine with a/t. I would check if it's tighten. tighten kickdown cable kasi gives the sipa and hataw feeling at start.
this is just my personal experience with old 2nd hand diesel vehicles and I know nothing with new Engines specialy Gas one.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
