Results 1,141 to 1,150 of 6591
May 9th, 2006 12:32 AM #1141
iirc the rancho series, like 5xxx and 9xxx, yun din price nila, same as model number.
the oem gen2.5 pajero adjustable shocks cost 8K each from el dorado.
May 9th, 2006 05:15 AM #1142
ngundam parts for calibration.
repair kit 615
oil seal 155
shim plunger 155
washer flyweight 155
driveshaft 1020
feed pump assy 1225
cover, feed pump 460
1 fuel filter bosch 500
bushing 310 x2 620
delivery valve 870 x 4 3480
nozzle tip zexel 1530 x 4 6120
washer return 45 x 4 180
labor package 4m40 2170
16,855 total
mukhang akong nauna sa nagpacalibrate. 74k tinakbo 99 model
May 9th, 2006 05:41 AM #1143
ask ko nga how much these would be sa el dorado...with discount. :D
will reply back asap as soon as i get the info.
May 9th, 2006 11:23 AM #1144
Originally Posted by nugundam93
Rancho shocks 5xxx and 9xxx series may adjustable ba nito? Saan ako pwede makabili nito? Saan mura?
Tsikot Member Rank 4
- Jan 2003
- 2,979
May 9th, 2006 06:59 PM #1145guys ask ko lang bakit mahina humatak yun paje nung officemate ko. pinatatanong kasi nya sa kin. gas na v6 yata yun. montero sya. alam ko USDM. pinagawa daw nya tapos nung binalik sa kanya mahina na humatak pag nilagay sa Drive pero pag reverse ok naman. Sinubukan ko nga i-drive at malaki nga difference considering diesel yun sa kin at gas yun kanya. mas mabigat naman yun rig ko kasi may bullbar at mabibigat na speakers plus mas malalaking gulong.... saka parang ipit yun accelerator pedal nya kasi di kagad bumabalik yun pedal
May 9th, 2006 10:39 PM #1146
SOHC or DOHC ba yung V6 niya? May mga issues ang DOHC regarding 'butterfly valves' nabasa ko lang sa 4x4wire.com. If you need gasoline advice, ok dun kasi sila mismo nag-ooverhaul ng sariling engines nila.
May 10th, 2006 01:48 AM #1147
Originally Posted by badsekktor
of course Gasoline are best for top speeds because they can go far more rpm's than diesels.
or maybe it's transmission related? kasi ok naman sa Reverse...
May 10th, 2006 03:56 AM #1148
lars, yung nxxx where n is the 1st digit nung series, yun din yung adjustable settings. so the 5xxx is 5-way, and so on :D
promdiboy, i'll try to canvas those parts sa el dorado (with discount. hehehe) later. will post asap once i have the info.
badsekktor, baka nga tranny issue na yan, ok naman sa reverse eh.
May 10th, 2006 10:11 AM #1149
*badsekktor: No idea with v6 montero engines, but if it were the old diesel engines with A/T, I would check the kickdown cable just to make sure .
- Jan 2003
- 62
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
