Results 1,131 to 1,140 of 6591
- Apr 2006
- 43
April 27th, 2006 12:18 AM #1131Hi, I have a few questions if you don't mind.
1. When was the 4x4 variant released? 1999-2000?
2. Does it come with a manual or an automatic transmission?
3. How much is the going rate for this model?
Thank you.
April 27th, 2006 05:50 AM #1132
Levi so far no problems pa sa mga fans. evaporator palang napalitan ko sa aircon sa harap.
klaus. 99 to early 2000 ang 4x4, may manual may auto tranny. mga 750 to 800k siguro 99 model.
peeps, nagpalinis na ba kayo ng injectors? or calibration or re tappet? napalitan ko na kasi glow plugs ko, but sa morning minsan namamatayan parin ako. bumababa idle ko.after that 1 click na the whole day.
April 27th, 2006 05:40 PM #1133
levi: i just had a problem with the aux fans about 2-3 weeks ago. the carbon brushes were replaced and it helped a bit, but still not up to spec, so definitely they (aux fans) need to be replaced. a/c is still cool but initially, the temp gauge at the center console and the temp gauge at the dash was nearing the red zone. anyway, after the brushes were replaced, it;'s doing ok so far, though the temp on the center console goes up again when stuck in traffic.
May 7th, 2006 01:32 AM #1134
pajero peeps., di ko parin masolve yung problem sa hardstarting sa umaga and namamatayan din paminsan pag morning start. bago na glowplugs ko. sinubukan ko dalhin sa denso and central diesel clinic, hindi na sinilip yung engine sinabi ko lang yung symptoms meron na agad sila rough estimate. 17k daw baba injection pump. meron na ba sa inyo nagpacalibrate ng injection pump? pls help medyo mabigat kasi yung gastos. 75k mileage ko 99 model, sa quotation kasama yung mga seals, plunger, nozzle tips etc etc. 1500 yung zexel while orig is 2400.
May 7th, 2006 10:07 PM #1135
sir promdiboy, could you pm me a list of all the parts needed to be replaced? saan yung parts bibilhin?
:D
May 7th, 2006 11:20 PM #1136
http://www.babbaraju.com/online/gallery.html
Hayuf mag-leather wrap ng mga 'to. Pati gitna ng manubela binalot! hehehe
May 7th, 2006 11:25 PM #1137
lupit nun ah! saan yan otep?
not too hot about the center of the wheel being wrapped though...for airbag deployment reasons anyway :D
May 7th, 2006 11:27 PM #1138
Sa India ata iyan. Check out the gallery. Innova na mukhang catfish, Crosswind na Chevy ang tatak, and the quirky Tata Safari.
May 8th, 2006 01:09 PM #1140
Mga peeps tanong ko lang is How much bang shocks na adjustable?
Ano brand ang magandang bilin? For Montero Gen.1
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
