me magnanakaw bang umaamin na kawatan sila?
SUA claimants: find same incident with Thailand users!!!!
or try this - left foot at the brakes, floor the accelerator pedal with your right foot.
Kun napaabot mo sa 3-4k rpm yan without shutting down the engine - that's something.
also, you can only start your engine on P and N positions.
gud pm po, nasubukan nyo po ba mag park ng nakabukas ang pinto driver side tas naka labas left na paa sa pinto, para ma tantsa ang parking space or whatever.... nasubukan ko sa innova AT at altis AT na nasa D ang shifter para umusad na ng nde nag gagas, imbes na brake ang tapakan, gas ang natapakan, in short nalilito ang right foot sa dalawa pag ganun ang position mo, buti nalang handbrake agad, so malamang driver error ang case nato
na witness ko yung tong SUA na to sa GB5, pero not a montero but a tucson. the lady driver, being assisted by carwash boy, was parking backwards. the man was behind signalling to the driver to go on when suddenly it went "100kph-on-reverse". the carwash boy was safe and yung driver mukhang na whiplash
moral of the story, wag sasagarin ang tapak sa accelerator pag nagpapark ka![]()
I had a recent experience of SUA not on a Montero but a Fortuner, even stepping on the brakes couldn't bring the car to a halt, luckily, there was no nearby car in front of me, I put the transmission in neutral and put on the brakes to finally slow it down. At first, I was worried that there was something wrong with the car since it was submerged in the recent flood (the carpet was wet, but no serious damage), but upon testing, I found out that the accelerator pedal got stuck on the carton that I recently used to temporarily replaced my floormats since carton does a good job of absorbing water. I tried it several times with the engine off, and the pedal got stuck twice. Moral of the story? improper placements of floormats can lead to SUA.
pag sabay apakan ang brakes and accelarator, mas malakas ang brakes ah
Indeed sir, I'm quite relieved to find out that there was nothing wrong with the vehicle. It would be troublesome if its a technical issue since I'll always be nervous when driving it.
dapat pala may tali ung kaliwang paa..
at ung kanan lang gumagana..:D
hoax... akin na lang yang montero nyo na may sudden acceleration (kuno) hehehe...
oo nga. Siguro kasi basa yung carton, kaya pag apak ko nung accelerator, mukhang bumaon yung pedal sa carton. Ang di ko lang maintindihan ay kung bakit di kaya nung brakes na ma stop yung car, as in tuloy tuloy parin ang pag accelerate. nag slowdown lang after linagay ko sa neutral at saka nakayanan nung preno na i-slowdown yung car. possible kaya na maoverpower nung 3.0 Fort and brakes nya pag full throttle?
naka hook na ang floormat ng driverside sa montero, kung bibili kayo ng pang patong na mat dapat same cut or may paglalagyan ng hook, kc baka mag obstruct sa brake or clutch pag lagpas lagpas or pag dumudulas pa taas
sir mahina talaga brakes ng fortuner compare sa monterosport.
subukan mo sir. step on the brake using your left foot, then step on the gas using your right foot, lagay mo sa drive
medyo aandar pa din yun auto. then observed kung gaano kahina brake ng fortuner compare sa monterosport.
