I went to mitsubishi yesterday, and as usual unlimited drinks and all the pampering. I'm happy with the free check up, thanks to alleged SUA victim. After the change oil and everything, it flies like F18.
Noticed an unusual longer line at Diamond Motors Quezon Avenue of MS for maintenance... including one with Bias Network stickers.
Repeat a twisted tale many times, the gullible public will believe it enough to be gospel truth.
Interesting sticker by the MSCP group at the end...hehehe.
Saw in the news last night, pila sa mga Mitsubishi casas for the free check-up. I wonder what they are checking up when they don't know what & where the problem is coming from with the fact their claiming driver's error??? So what if they've check-up the vehicle then the next few days SUA happens, they blame the driver again?
Also in the news last night, drivers are staying away from Monteros on the road to escape from possible accident. They heed my call.
The other night we're at MOA Viking parking area. Pag tapat sa Montero naka park told my kids to stay away in front & at the back at baka umandar bigla yan. We all are:hysterical:
Actually, going through all the known issues and complaints regarding the 4D56, I can see the outline of a case beginning:
1. We know the inhibitor switch is faulty. Which means that inattentive drivers might not know they're in "Drive" instead of "Neutral"
2. Throttle surge due to voltage spikes and clogged EGR or SCV are not unknown. In fact, there are complaints about surge in other markets, but it is still supposedly controllable by the brakes.
3. An extended surge requires a more major malfunction, however, and possibly extra oil to burn... (oil leak in turbo?) which would have resulted in a bluish cloud rather than the black cloud in the White Monty video (there was some blue, but not all that much).
4. And you would still have to explain why the brakes didn't work.
5. And you would still have to explain why the brake lights didn't work for exactly one minute only.
The first two, however, could provide clues as to the cases of the ladies on the highway, though I think mat entrapment or mechanical throttle sticking cannot (and should not) be ruled out there.
Advice ko lang sa mga naka Montero ngayon is to install a cctv sa pedals para in case na ma SUA ang unit nila captured ang scene. Lalo na sa mga na experience na na nag SUA ang unit nila na hindi naman bumangga dahil may chance na maulit ang SUA ng units nila.
If mahuli lang sana sa cctv yan solve na ang case.
Ang easiest diy patch dyan, lagyan voltage clamp yung signal wire papunta sa throttle body voltage level same sa peak ng signal kapag engaged ang compressor. Clamp will be deactivated when you press the accelerator.
How can this be a driver's error. It run's perpendicular to the road direction thus are they saying the driver is soo damn that he/she want this to happen ? If a driver's error, the most it can do is bump the body not hump on the car. The came case dun sa Iloilo, she was just parking on the garage but then rammed the wall into the sala. How many times had she parked that park into her garage and suddenly she would like to ram her sala. And MMPC would claim driver's error. No wonder this problem is cannot be resolve cause MMPC keep's blaming the driver and that's more than 97 cases already. Is what MMPC stating is that their Montero drivers are damn stupid to cause accidents?
Wow, MMPC is phasing out the Montero Sports. If I were a common kanto boy, I would think it means there is something wrong with the Montero Sports. why else will they do that... :P They are admitting it because that is what ABiaS CBN said so...di ba?
Im not really sure what you mean and Im not an expert but I think Throttle body and Fuel injectors are not mechanically link (correct me if Im wrong) so controlling the Throttle body would not mean also controlling the amount of fuel fed. Remember that both air (controlled by throttle) and fuel (controlled by injectors) must be fed together for the engine to rev up as others wise it will be either too lean or too rich and bog the engine off instead of revving up
Controlling the throttle body is applicable for carburetor equipped fuel system.
Hindi ba misleading yung article ng ABS-CBN.
MMPC will phase out the 2015 Montero Sports which simply means they will stop selling it and move on to sell the 2016 model.
This is normal for any car distributor or dealer once a new model rolls out in their showroom.
Though MMPC admitted their doing it earlier than expected due to no sales since Dec1....
Mitsubishi warns of dire business impact if DTI issues recall of Montero | mb.com.ph | Philippine News
