Results 21 to 26 of 26
November 20th, 2009 09:10 AM #22
From a person who is using a surplus Mitsubishi van for more 4 years now, here are my two cents:
1. From personal experience, I still have to encounter a problem with my van's conversion kit or whatever you may call it. I always maintain that the conversion depends on the quality of how the vehicle was converted and the quality of the materials used.
2. FC? If the Dingo you're looking at has stick shift instead of A/T, I think would be close to 19-20 k/lit. Anyway, I could be wrong.
3. Spare parts? AFAIK the Dingo has an Orion/Cyclone 4G13/4G15 gas engine. Parts for these engines are available at Banawe. AFAIK, the Dingo shares the same underchassis parts with the Lancer so of this would be the case, then the parts will also be easily available at Banawe.
- Sep 2007
- 3
November 20th, 2009 09:39 PM #23240k pala kahit sa CEZA? sa Cainta raw kasi around 250k ang price. so not much reason to go there. pero may nakapagsabi sa akin na ang price daw doon ay 170k to 190k, though hindi masabi kung saan dun. ito ang inaalam ko ngayon. meron po ba kayang makakapagbigay ng tip dito kung ano ang price range ng Dingo sa CEZA and dito sa MM? maraming salamat sa makakapag-tip.
if the Dingo underchassis parts are indeed the same as Lancer's then maintenance won't be much of a problem. sana nga pati engine parts din ay readily available sa Banawe.
- Mar 2010
- 8
March 25th, 2010 01:32 AM #24sir san kayo nagpapaservice ng mirage dingo nyo? may problema yung dingo ko ngayon eh... baka may marefer kayo na expert sa japan cars lalo sa mitsu mirage dingo. thanks.
BTW taga san juan MM pala ako..
August 24th, 2010 11:01 PM #25
AFAIK lahat ng dingo ay galing sa subic na costs around 200-300k
AFAIK lahat ng dingo galing japan d ko sure kung may orig LHD
maganda ung built ng dingo and kinda convincing type kung ang hanap mo ay fuel efficiency type vehicles. it comes with a 1.5 CDI engine (d ko lam ung engine code) pero some say malakas daw sa gas ung iba,, nabasa ko lng sa ibang tread un
well eto lang ang napapasin ko for now
August 24th, 2010 11:07 PM #26
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
