YUP! You're absolutely right. A very reliable vehicle indeed.
2nd owner(L300 vv gas '92).
Acquired April 2007. Kailangan ng minimal body repair(of course) and painting.
Pag may budget na...
Mas matutuwa ka...
Dual Fuel na ako!(LPG & Gasoline)![]()
Mas matutuwa ka...
paano po ba 'ung dual fuel? magkano po ba ang total cost magpa-LPG?
i tried regular gasoline (87-89 ron, i think; not the 93) it works but it caused a lot of knocking and required higher rpm shift points, so it's not necessarily cheaper. my default is caltex with techron silver, but i'm now using xcs.
clocked in more than 700 kilometers over the long weekend. ok naman. kaya pala around 10 kpl 'pag long trip. i get around 8 kpl in city use.
i noticed that for some reason, the lock on the clutch cable and the lock on one transmission cable were missing, so i replaced with stainless wire.
Last March 2010 ako nag-dual fuel.
Open-loop(the simple one).
Toroidal(donut) type 40L tank.(may mas malaki pa yata)
Protection shield ng tank(installed replacing the spare tire )
Kaya spare nasa loob na lang.
Umabot ng P25,500.
In terms of FC, parehas lang sila ng gasoline.
Mas mura lang ang LPG.
Nga pala, LPG is 100+(RON).
good day! diy projects ko po last weekend:
- repositioned the window guide--hindi na kailangan hawakan 'pag isinasara, together with new rubber run channel (php300) for front-right window;
- installed new tighter bolt (php20) for shift lever
- tapped 5w turn signals to parklight
- new universal 5w light (php60+wire) at license plate
'ung nakasabay kong versa van sa auto supply, dumidikit naman ang drum brake niya.
mayroon po ba sa inyong may owner's manual?
Mga Sir's,
Good day!!! medyo matagal narin akong di nakaka share at read dito....Baka pwedeng malaman kung meron bang lumabas na Parts Catalogue ng L300 Versa Van 2003 Diesel?
salamat po!!!!!!!![]()
Sa CASA malamang meron!
Di ko lang alam kung may pinag-kaiba iyong bago sa lumang catalog.
Sa El Dorado mayroon, pati replacement parts.![]()
Please let me join.
New here.
Just got a second hand Versa van 98 model recently(diesel - green)
This is my 6th vehicle,family is getting bigger so I switch from a sedan to L300.
Preventive and Corrective Maintenance done last weekend;
1.Tune up-all belts and oils changed - to make it sure wala na kakaba kaba
2. All breaks cleaned,balance and parts replaced -
3.4 new tires - i dont like the old tires when i bought it
4.Camber,alignment,tie rod,arm replaced.- assurance
5.New 12" momo steering wheel - i dont feel comfortable with the stock 15 " steering wheel
6.Left doors upholstery repaired.
7.Change seat cover from gray to black
8.Next in line , will be aircon cleaning,sound system,bullbar,alarm,some dents,front and back mirrors and scratches repair.
I am happy with my dream van so with my family during our weekend bonding.
Got no space problem with all of my airsoft gears during weekend game.
I will be appreciating comments and suggestion.thank you
can you recommend a good shocks for L300 FB?
brand and model no.?
over 180k + sir,approx 200k mileage.with dents and few scratches din po
blessed last saturday plus new pioneer car stereo,2 new speaker and front bullbar.
next in line rear bumper guard,air con cleaning and change seatbelt.
medyo maluwag po now with my family during weekend malling to lipa city from tanauan city
Last edited by Chito M.Tarzona; September 26th, 2011 at 11:04 AM. Reason: typo error
stock po lahat, sir. 1995 gas, 4g63, may 164,000+ km nung nakuha ko. naipa-overhaul na po daw ng dating may-ari.
sir, no aircon, because my aircon is broken. early shift and maintaining 60-80 kph.
the following are new:
- timing belt and timing adjustment by servitek
- some other parts changed together with the timing belt
- clutch
- motor oil (castrol magnatec)
- transmission oil (mobil mobilube)
- differential oil (same mobil mobilube)
- engine treatment (cyclo because i could not find x-1r then)
- air filter
- starter was repaired
- speedometer gear (hindi bago, pero binaligtad lang para 'ung kabila naman ang mapudpod)
suspension parts, brake pads, and brake overhaul kit are new. when i got my versa van gas 3 months ago, it felt very strained at 80-90 kph. it runs better now.
mga sir pa join, new owner lang ako ng L300 FB Exceed 2011.
thanks...
Any idea on Tranmission(6 gear perhaps?). to improve FC?
Or bigger tires(kahit likod lang).
4th and 5th gear, parang 2 teeth lang difference eh.
