Results 1 to 10 of 24
- Jan 2003
- 25
August 27th, 2003 07:28 AM #1just want to know.... what problems do you guys encountered with your galant? i also have a galant supersalon 95 model... thanks....:confused:
August 27th, 2003 07:57 AM #2
problematic areas of the 7g galant include a weak underchassis (suspension arms, shocks, etc.) and a tendency of the disc brakes to warp. just make sure that you undergo the regular PMS and you're set to go :D
mejo weak din ang A/T variant nito eh.
basically eto lang ang problems na na-encounter ko. i suggest you replace the OEM fluid type shocks to more firm, and sturdy gas shocks. negligible difference in terms of ride quality. makes the chassis a bit more firm lang. sarap ng hatak ng 4g63 makina ng super saloon, matakaw nga lang sa gas pag pedal to the metal driver ka.
i'm experimenting on using a laid back driving style, e.g. shifting up at around 2.5k sa tach para malaman ko kung ano magiging fuel economy ko
HTH
- Aug 2003
- 120
August 27th, 2003 12:09 PM #3suspension nga yun mahina.. lagi may sira ng bushing.. plus the fact that most of the front suspension bushing are not swappable. so you have to change the whole arm.
speaking of disc warp, am having mine re-faced on thur.. and hopefully upgrade to better pads/fluids as well
despite those problems, the 7g galant is a great car. comfortable for long drives, stable at speed..
its hard to go back to tiny 1.6L after you've gone 2L :P
- 106
August 27th, 2003 04:09 PM #4sa amin..
1. suspension arm at 25k kms (P9,000)
2. a/t tranny at 40k kms (its starts in 3rd gear and usually overheats after 1 hour on driving. estimated repair by casa is P100k, pina-remedyo lang namin muna sa isang shop, dapat lang laging o/d off...cost was 10k, but we havent drove it ng malayo. for coding nalang)
comfy naman ang ride, engine power is also ok.
August 27th, 2003 11:38 PM #5
lateral arms on both sides. aside from dat, i noticed dat wen turning left on rough surfaces, ders a knocking sound on the driver's side underchassis components. suspension uli yun, but my car is a '97 model vr. normal wear and tear na siguro after 6yrs, yung mga lateral arms na pinalitan ang premature wear n tear
September 1st, 2003 06:00 PM #6
I agree with the people have posted here. Suspension is one point against it. Another would be that damned A/T. Citimotors was charging us P100K din! :whoa: Siyempre di kami kakagat no, sira pala sila eh! Buti na lang may mga friends kami na taga-citimotors, so sinideline na lang namen. In the end it cost us around P30K, pinalitan yung clutch disc, pressure plate, etc,etc.
Apart from those things, I like that car. It's fast, stable at HIGH speed:D , masarap lalo na pag long drive!
- 230
September 2nd, 2003 05:56 PM #7we also had suspension problems with our 94 VR, mostly on the bushings.
but i like the engine. di ka kakapusin sa power, but not as refined as the next generation galant's 2.5 V6 or the nissan cefiro V6.
September 2nd, 2003 08:19 PM #8
but the 8g 4g63 sohc powerplant really sucked IMO... ang bagal na tlga compared to the previous model of the same trim.
September 3rd, 2003 02:48 AM #9
i have a '93 GTi Galant converted to automatic, ano b solution pag yun transmission masyado na malakas ang vibration pag idle lang or pag naka drive at full stop?
- Nov 2002
- 22
September 3rd, 2003 04:25 AM #10Own a 97 Galant ES and had a recall to replace the suspension arm including bolt-joints. hindi pa sira pero pinalitan ng Mitsu Motors Corp of USA.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
