Older mechanics use electrical tape, pero meron talagang specific kind para dyan, di ko lang maalala yung nakasulat dun. I think I saw that in Ace hardware.
same lang ba under chassis parts ng l300 versa van and delica?
fierari,
thats an space gear right?we got one before at around 450k if im not mistaken,ganda nga,especially the 4m40 engine and super select 4x4.but we sold it already.
Ok thanks I'll try to browse thru Ace Hardware next time I get a chance to visit it.Originally posted by Ungas
maganda nga yung space gear na 4X4, I saw one when I was on vacation dyan sa atin...white ang color and maganda pa ring tingnan...4M40 na ba yung engine non? wowee....parang gusto ko na rin nyan...hehehe
Hello,
Tatanong ko lang po, kung okay lang po ba palitan ng mas maliit na gulong ang delica para hindi siya mataas, what specs of tires should be used and the pros and cons of changing the tires. TIA!
Yung mga Star Wagons madaming common parts with GEN I Pajero, L300 Exceed and Hyundai Grace.
matibay ito mga delica kasi yun nabili namin isa naka 180T kms na buhay pa din.
Originally posted by pajerokid
AFAIK, 4m40 na yung space gear. suspension is gen2.5 based ;)
nde ba taubin ito pag pinag offroad?
naka pag off-road na ako gamit yun delica hindi naman kami tumaub basta dahan dahan lang
guys,
OT pero ano ba kaparehang shocks ng delica?same lang ba sila sa l300 versa van?
fierari,
Kahit ano namang 4x4 taubin. hehehehe. Malamang mas taubin pa yung mga lifted na LC40 kaysa diyan.
Nikko m,
Yung sa harap same ata as GEN I Pajero. Yung sa likod hindi ko alam. :D
Dapat yata mabuway hindi taubin. Pag nadaanan ng truck o bus sa gilid buong body nadadala ng hangin.
otep,
oic,so malamang same din sila ng rear shocks ng gen1,ang hirap kce bumili ng parts minsan pag walang sample eh,eh the unit is on our prov. kelangan pang mag padala ng sample if ever.
Helo, im new here, and just got our delica star wagon about a month ago, it was in great condition, until recently na discover namin na nagleak ang power steering fluid, had it checked and sabi na ang leak is from the rack and pinion assembly ng delica... nagtanong tanong ako sa ibang mekanik and surplus shop, ang sabi nila samin is that since and delica ay converted RHD to LHD, and rack and pinion assembly nito ay possibly from other brand like nissan or toyota... any delica experts there know about this things?
Sir sure ka rack and pinion? truck based yan and it usually uses a recirculating ball & nut? if its a leak it must be an oil seal... kung yun nga me oil seal centre like Simplex on 6th ave. cor avenida Kalookan which has all kinds of oil seals. I got mine there when I had my steering box repaired. I wouldn't buy a surplus for that, its a wear and tear item. When you have the sample, bring it there or call them to make sure they have stock, if they dont I think they can fabricate you one but it has a minimum of 3 pcs order yata.
my deli is a series 1 4m40 auto exceed.
nakapag inspect na ako ng steering mechanism nya.rack and pinion sya. malapit sa toyota hi-ace ang parts nya.nung nag palit ako,pinakita ko sa auto supply ang sample. pang toyota nga ang rack end at tie rod.may makukuhang parts nito sa banawe (gilid nga lang).
suggestion lang:
pa check mo agad ang brakes na apat.disk brake lahat na yan. tignan mo ang pads at kung gumagalaw pa ang caliper.prone kasi sa seizure ang mga yan.
palitan nyo na din agad ang plastic na expansion tank ng radiator.usually 10 years lang yan at kailangan palitan.prone ka sa over heat pag hindi mo na plitan.mga 6k yan sa el dorado.pag bukas mo ng hood ay malapit yan sa preno.may radiator cap.distilled water ang ilagay para hindi kalawangin.
pa check din ang alternator kung malakas pang kumarga
sa ilalim ng blower ng intercooler ay lagyan mo ng pading ang upper radiator hose para hindi mabutas.
i block mo ang egr(exhaust gas recirculation).lagyan mo lang ng plates.hindi kailangan yan sa pinas.at para lalong gumnda takbo.nasa exhaust manifold yon malapit sa turbo
paminsan minsan ay i engage mo ang 4wd nyang 3(super selct,hi,lo).para hindi mag stuck up. yung hi at lo setting ay bawal gamitin sa semento at aspalto o matigas na daan.masisira ang transmission
sana makatulong sa iyo
