Results 1 to 9 of 9
    May 2017
    Hello there,
    Maybe guys you have an idea what is going on with my lancer 94. The idle goes up when i turn on the AC at the same time di lumalamig, di naikot fan ng aircon. Minsan gumagana AC pag bunuksan at di tumaas ang idle... pero pag nramdaman ko tumaas n ang idle, mwawala lamig ng aircon. Usually i turn off the AC then idle will go back to normal.. anu kya sira nito. Meron b need adjust lang? Or linisin or palitan.. i dont have any idea. Thanks.
    Quote Originally Posted by Ocram View Post
    Hello there,
    bring it to the aircon shop, po.
    too many suspects, from defective/intermittent switches and/or solenoids, to defective/intermittent compressors, to defective idle-ups, to...
    if you have friends who will swear to the honesty of their favorite aircon shops....
    May 2017
    Thanks for your advice sir. I will do that once makakita ng matino at di tagang shop.
    I just encountered recently na pdagdag ng pdagdag ang problema at dpt palitan nung nagkaproblem ang auto last month.
    By the way kahapon till as of the moment di pa nagnonormal ulit yung AC. When i turn it on tumataas n agad idle and of course di n nalamig si aircon.
    turn on and taas idle but hindi lamig aircon...
    sounds like the idle-up is ok. that suggests, your problem is with the aircon system.
    May 2017
    Thanks sir. Pero nagtataka ron ako yung idle nya sobrang taas.. not the normal idle up when AC is on. Prang doble or triple ang taas. Umaandar n magisa ang kotse pag naka gear na..
    Sent from my SM-G610Y using Tsikot Forums mobile app
    errr... how long has that car been with you, po?
    May 2017
    Thanks sir for the help. Really appreciated it..
Lancer 94- idle goes up when AC is on, at the same time not cooling; fan is not rotating
