HELP!!! po in identifying Pajero FM local to Surplus..
d ko kc alam kung pano e identify local to surplus.. pa help po mga expert tungkol sa pajero FM coz im planning to buy one.. tnx po!!
mas ok po if you post some pix on local FM and surplus FM..
HOPING FOR MORE REPLIES.. GODBLESS!
I have a Gas Pajero Gen 2, but I can probably help you out. These are the few things that you can check:
1) Plates - If it starts with a "C", 90% are JDM
2) Transmission - Most local FM are Matic. AFAIK, Manual FM were only sold on the first year release which would fall on the plate letter "X"
3) Dash - If converted, they might have replaced it with a new LHD dash. Rare though that they transfer the Wood Dash Trims (Kahoy na sticker) to the new one if replaced.
4) Antennae - should be at the passenger side
5) Cluster Gauges - Altimeter should be at the rightmost side of the three cluster
6) Sunvisor - Everything else may be replaced, but the least that they would bother changing are the sunvisors. If it has a plain Japanese wordings and the vanity mirror is at the driver side, that's JDM.
Sliding glass should be replaced to a whole one (for local), if you ask me. For protection. I really don't see the use for it.
Mine is original LHD but replaced my sliding with whole quarter window.
If local FM yan and replaced na to whole windows, either 2 things lang: 1) nabasagan and nanakawan na sa loob; and 2) prevention is always better than cure
Yes James, exactly like that.
There are Gas FM V6. I can assure you that 99% are original LHD. Plus they have a sun roof. Bloody lang fuel consumption.
