Results 1 to 6 of 6
February 26th, 2010 03:41 AM #1
mga sir, patulong naman... ndi umaandar ung aux fan ko pag naka off ung aircon ko... sabay na umaandar ung aux fan ng radiator tska aircon ko pag naka on aircon ko... pag off ung aircon ndi ng aautomatic ung auxiliary ng radiator... ano kaya problem nung aux fan mga sir? muntikan na ksi mg overheat ung oto ko knina, buti napansin ko ung temp na tumataas kaya naitabi ko agad, nag paayos ksi ako ng window sa banawe kaya ndi na ako nag aircon....
February 26th, 2010 06:10 AM #2
umaandar ba yung fan pag naka aircon ka, or hindi umaandar?
pag umaandar naman, mahina na siguro ikot. palitan mo na. mura lang yun, mga 1,500.
pag hindi talaga umaandar, palitan mo na rin. ganun din yan summa total palit ka rin. or tignan mo yung auto switch nya baka nagka ground.
February 26th, 2010 01:23 PM #3
gumagana pa ung aux fan sir... mabilis pa ung ikot... ang problema ko, kelangan na naka on ung aircon para gumana ung aux fan nung radiator... dba automatic dapat ung fan pag mainit ung radiator, kahit na naka off ung aircon mag aautomatic un? ndi kasi tlga gumagana ung aux fan pag off ung aircon... san ko ba makikita ung cnasabi mo na switch sir?
- Feb 2010
- 14
February 26th, 2010 02:52 PM #4
February 26th, 2010 03:32 PM #5
san ko makikita ung relay sir? quezon city area ko sir, sa batasan... '93 lancer po pla oto ko sir...
- Jan 2011
- 8
April 25th, 2011 10:22 PM #6My car is Mitsu Galant SS 91 model. It has 2 fans or blowers, the aricon fan and the aux fan. The aircon fan will only turn on when the aircon is on. The aux fan will only turn on when the engine gets hot. If it doesn't turn on, your car will overheat even if the aircon fan is running, its not enough. These 2 fans are not dependent on one another.
Electrical wiring was the problem for my car. The was a scenario when the aux fan runs automatically and that my aircon fan turns on also, even if the aircon is off.
For your case, electrical might also be the culprit. If both your fans are running then both are ok. I would say that the wiring for the aux fan is incorrect. It should be dependent on the thermoswitch connected in the radiator. So check the wiring, check your thermoswitch, check your relays.
