Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2004
    guys, yesterday, i did some light trailing with my gen 2 pajero. when we got to the house, my friend pointed out that i split my rear stepboard on my gen 2 pajero, the light alloy/aluminum thing under the tow hitch.
    parang design flaw ata ito because upon inspection, the stepboard has a spring mechanism for it to flip up. problem is, when it flips up, it runs right into the tow hitch.
    so i am assuming that when i went up an incline, my rear angle must have been too sharp, therefore flipping the stepboard up, right into the hitch, splitting it in two when it was squeezed between the ground and the tow hitch
    anyway, i will be removing it because it compromises my departure angle (and i do not want to spend money to replace it)
    has this happened to anyone else?
    andy
    the same sad thing happened to kcboy when we took to the payanig tracks before. good thing is, you can get those aluminum steps surplus. i have no idea lang how much.
    Aug 2003
    ask Sir kimps may contact sa kapalangan kung magkano
    Feb 2004
    anyone with a price estimate? if i do buy one, di ko muna ikabit. mkhang gusto ko na tuloy gawing off road machine ang aking gen 2 pajero after yesterdays trailing.
    i might do what otep did to his pajero. I may have a donor for some used 32 inch mud terrains, so ang kailangan ko na lang is the spacer for the rear and a slight torsion crank. stock rims muna ako, wala pang pera
    andy
    I took my center step off a long time ago. That way, the pintle hook hits the terrain first. Tinago ko na lang in case the time comes to sell the Pajero.
    Ok naman ang porma kapag walang center step.
    Yesterday I backed into a trash can in my father's Montero (equipped with the rear step). If the step wasn't there, the pintle hook would have easily pushed that big can back instead of scratching the step.
    Feb 2004
    yup, okay naman ang porma. did you live that bar underneath on?
    left it on for added protection of my bumper but ang problema, di masyado maganda tingnan ang two mounting locations for the rear step. parang sarap tangalin pero kung tinanggal ko, di ko na mabalik come time to sell my truck.
    Otep, where did you buy your coil spacer for the rear again? how about your 1/4 inch spacers?
    thanks,
    andy
    I took everything out including the chassis mounted bars.
    It's just held on by four bolts. Madali lang alisin.
    32" tires will easily clear a Pajero. I'm using 33" tires kaya may spacer. The spacers are available from GlennSters shop at around Php 200.00 each.
    If you use 12.5" wide tires (like I did), you will have some rubbing at the swaybar when turning the steering wheel to full lock.
    Feb 2004
    otep, how about the 1/4 inch spacers? does glennster also carry them? i want a wider stance pero can't afford new mags pa
    do you have the email or phone number of glennster?
    thanks,
    andy
    thanks,
    andy
    Spacers for a wider stance are available from GlennSter's. I think it's Php 350.00 for a pair. But you have to call ahead to make sure they have some in stock.
    09198524960 is Glenn's number. But it would be better if you called his cousin Ronald down at the shop at 02-9218831 para ma-check na niya agad.
    Feb 2004
    thanks otep, i will call them tomorrow.
    andy
    PK,
    u still remember i damaged the rear step sa paj ko. anyway, if any1 knows a surplus 1, tell me so i can buy 1 as spare.
    Feb 2004
    me too kung may mahanap kayo na surplus, please tell me.
    yung mayari ng mitsubishi na kaibigan ko dito, may dalawang gen 2.5 na pajero. sinabihan ko na kung mawala rear stepboard nila, hindi ako ang kumuha nun
    andy
    luckytruck, pm mo si ECG /Olive Drab, alam ko may extra Wheel Spacer siya na galing sa BJ41 niya.
    about the bumpers, tignan ko kung makakapunta ako sa surplus land dito sa apalit sa friday,
    teka di ba sa gensan ka pa?
    Aug 2003
    kim, 1 inch ata spacer ni ECG
    bro kung matutuloy ka patanong naman ng right side mirror ng prado yung local version...kung mayroon and magkano...tnx ... and yung grill na bago kung mayroon pa
    if ever wala ka kasama...papunta doon...sama mo ako lols...di pa ako nakaka punta doon :D
    2pm nasa sn fdo na ako from clark.
    Feb 2004
    yup, nasa gen santos ako but i can ask some of my friends there in manila to get it for me.
    yung spacer na 1/4 inch para sa wider stance, will it compromise the reliability of the pajero's wheels? since mabawasan ng 1/4 inch ang kapit ng lugs sa bolt?
    by the way, share lko lang, i will be designing my own rear step board na lang, hope fully maganada ang labas bili pa ako ng bakal ngayong hapon.
    thanks,
    andy
    Feb 2004
    anyone with any opinion on this?
    andy
    It won't help with wider stance look. That's only 5-7mm distance. Better switch to a wider spec set of wheels with 15x10.
    Feb 2004
    i am not too keen on going to 15 x 10 inch rims. baka nakalabas na masyado sa fenders ko ang gulong.
    i just want the tires to be flush with the side of the body. pwede na kaya ang 15x 8 na rims?
    andy
    May 2004
    Tires shouldn't be all that flush with the side of the body, unless you don't mind having bits of dirt, water and mud flying up the sides and sometimes into an open window. The wheel well should fully enclose the tire to prevent this.
    You cannot attain the wider look that you want with 15x8. Either switch to 15x10 or remain stock without wide stance look.
broke my rear stepboard on gen 2 pajero: aaaargh
