Results 1 to 10 of 56
    Apr 2008
    Quote Originally Posted by m8m8 View Post
    Guyz, baka my nka xperienced rn s nyo nito, hopefully matulungan nyo ko..
    during start s umaga, nid mo painitin muna yung car para taas ang rpm, also pag ON mo nmn ang A/C, ngda-drop sya from 1000-600rpm. as per mechanic, sira dw servo, so buy me ng servo unit s el dorado, ako n lng ngpalit but still no changes s car. so, dnala ko s casa (sta.rosa), naayos nila servo and did some adjustment. Now, ok n pag start mo s umaga, the rpm rise to 2000 then slowly baba to your set rpm. But the problem w/ the A/C is not solve yet, when u switch ON the A/C, the rpm drop to 500 (nginig n engine) then goes back to set rpm w/in 2secs. the casa told me that the a/c control unit need to be replace (di ko p pinapalitan), so far d nmn natutuluyan mamatayan ng engine.
    kaya lang after a month, natutuluyan n mamatay ang engine kpg nasa traffic (idle), i encountered it several times na. So, punta ako s iba shop (ex-casa mitsubishi personnel), they did tune-up (replaced spark plug),chk distributor cap, coil.. but still ganun parn, d parn n solve yung problem. As accdng to them, kung sira yung A/Ccu, n compressor won't operate. At yn, ala maibigay n recommendation aside s itama ko rw ang timing (kulang ata ng isang ngipin)).
    Also, ngpalit rn pala me ng high tension wire (oem), linis fuel filter,
    EFI, gli, 96 lancer model nga pala ride ko.
    Any help dyan or recommendation po.. thanks..
    Bro I do servo bypass specially for aircon purposes for only 1,500. You can text me at 09217387401, 09165706310 or 09233067779.
    Apr 2008
    if your idle is like playing around i.e going up and down try checking your aic vavle.
    May 2005
    experience that also w/ our 91 Lancer GTi. Nung una palit servo, ganun pa din. Palit naman computer box, ganun parin. Nung pinalitan ang Throttle Body e tsaka lang sya tumino.
    Jun 2007
    pacheck mo rin aircon baka naghigh compression as stated dun sa mymitsu forums
    Quote Originally Posted by eybalbin View Post
    ok ang bypass incase na sira na ung servo, sobrang effective na remedyo un. But in this case bago na po ung servo nya so obviously may mechanism na nag cocontrol ng systema ng idling.. not only aircon pero pati lahat ng gumagamit ng kuryente or nagbibigay ng load sa makina. Kung napalitan na ng new servo unit, what the sense kung mag papabypass pa. Siguro may iba pang problem ung car kaya ganun... mas maganda siguro na mag bigay po tau ng input na makakatulong ng malaki sa problema.. rather than making business..
    ganito din kase problema ko... tnx po
    Feb 2012
    ebalbin di ko
    emule, btjunkie, gamesmacontact ung binigay mo # san ba location mo at anung klaseng bypass ba ung gagawin mo?? sa 1500 sayo na lhat ung materials ng pag by pass
Lancer Idling problem
