Results 1 to 10 of 27
- Aug 2003
- 46
October 19th, 2006 11:14 PM #1oks lang kaya ito?
imbis na papunta sa intake manifold
lagyan ng breather
kasi tingin ko kaya mausok kasi yung oil pumupunta sa intake manifold tapos nasusunog sa exhaust....
at normal ba pag binuksan yung oil cap tumatalsik palabas mga oil?
4d56 engine pala diesel
anybodys help will be appreciate thnx in advance!
October 19th, 2006 11:18 PM #2
Pwede naman yung gusto mo.
Yes, talagang may tumatalsik na oil minsan. Basta huwag sobra.
- Aug 2003
- 46
October 19th, 2006 11:24 PM #3sir otep,
tama ba yung observation ko na mababawasan yung black smoke kasi di na dadaan sa exhaust manifold at di na masusunog yung oil...?
at napansin ko basa sa oil yung breather is this normal?
October 19th, 2006 11:25 PM #4
Hindi na po ako sure sa part na iyan.
May oil din ako sa breather, btw.
- Aug 2003
- 46
October 19th, 2006 11:37 PM #5naka breather karin pala
di pala ako nag iisa hehehe
im on the right track pala
actually bagong kabit ko palang ito and im still observing kung ok siya.
every when mo nililinis yung breather?
parehas lang ba aircleaner ng pajero at L300? yung bilog na mahaba?
naka K&N kaba? binalak ko kasi bumili dati sa states kaso natatakot ako baka nde compatible kasi wala naman L3 dun
- Dec 2005
- 46
October 20th, 2006 04:02 PM #6I think its normal to have a little oil on the breather hose but not too much. Normal din yung may talsik na oil from the oil filler for the 4D56 wag lang sobra.
I've installed also a breather (looks like a small air cleaner) instead of the breather hose except that I noticed that there is a slight higher pressure coming out of the oil filler as compared to having the breather hose fed into the air cleaner intake hose. I also noticed that less black exhaust smoke without the breather hose too and seems I get a lower emission score without the breather hose connected.
October 20th, 2006 05:34 PM #7
you can make an oil catch can, maybe I'll picture my own catch can so that u can make your own, that is made of PCV pipe L shape with 2 holes top and bottom,with cut foam inside. Size of the pipe 2" diameter.
- Aug 2003
- 46
BANNED BANNED BANNED
- 3,790
October 21st, 2006 08:38 PM #9mausok ang L300 because of the engine design, maliit ang piston at mahaba ang stoke....not because of that
October 21st, 2006 09:09 PM #10
mga sirs ano po ba yang breather na yan puwede po ba kayo mag post na pictures and yung oil catch can po thank you po mga sir's
It looks like solid state batteries are the next big thing. Will manufacturers allow retrofits to...
All New Toyota Corolla Cross
