Results 571 to 580 of 2048
- May 2008
- 290
October 12th, 2010 12:57 PM #572
Anyone notice the 2.5 VGT has a higher power/torque than the present 3.2 DID. It would make sense to phase out the 3.2 GLS SE since the engine is used in the upper Pajero model.
4D56
Displacement - 2.5 L (2,476 cc)
Bore - 91.1 mm
Stroke - 95.0 mm
Fuel type - Diesel
Intercooled Turbo (3rd Generation DI-D with variable geometry turbo)
Power - 130 kW (175 hp) * 4000 rpm
Torque - 400 N·m (295 ft·lb) * 2000 rpm
Engine type - Inline 4 cylinder
Fuel system - 2nd Generation Common Rail Direct Injection (CRDi)
Compression ratio - 16.5:1[18]
Applications:
2001-present Mitsubishi Space Gear/Triton/L200/Strada
2009-present Mitsubishi PajeroSport/MonteroSport
4M41
Displacement — 3200 cc
Bore — 98.5 mm
Stroke — 105.0 mm
Fuel type — Diesel
Intercooled turbo
Fuel system — Electronic control type distributor type pump (direct injection inside diesel tube) or Common Rail Direct Injection
Compression ratio — 17:1
Power — 121 kW (165 PS) at 4000 rpm
Torque — 351 N·m (259 lb·ft) at 2000-3000 rpm
Applications:
1999-2006 Mitsubishi Pajero
2005-present Mitsubishi Triton / L200 / Strada
2006-present Mitsubishi Pajero
2009-present Mitsubishi Pajero Sport / Montero Sport
October 13th, 2010 10:31 AM #573
[SIZE=3]I placed my doubt in the display of my MS 2.5 GLS, when I left home the other day, the display is that the Diesel I have presently can cover 190 km run, so I left kalookan-airport-kalookan, when I returned home it is still 190 km which mean not right.[/SIZE]
[SIZE=3]So any idea if there is way to calibrate & makes it reliable equipment & not just pang porma lang. Also I tried the elevation reading, riding over the bridge(over pass) along edsa, wala rin pinagbago-elevation is 0.[/SIZE]
[SIZE=3]At present this are the issue of my MS almost 3month old.[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Thanks for any info-RTS[/SIZE]
- Nov 2009
- 4
October 13th, 2010 03:15 PM #574
October 13th, 2010 04:22 PM #576
- Oct 2010
- 109
October 13th, 2010 05:32 PM #577
October 13th, 2010 06:01 PM #578
- Oct 2010
- 109
October 13th, 2010 06:13 PM #579
- Jul 2006
- 3,376
October 13th, 2010 10:12 PM #580Sirs, nakalimutan niyo that the 4M41 engine is now on its 3rd generation. Even though may VGT na siya dati pa (Euro and Australian models), yung 3rd gen na 3.2 4M41 now has 197 hp and 441 Nm of torque! I saw it sa Mitsubishi Australia website. So for me, hindi i-phephase out ang 3.2 4M41. Instead, MMPC will introduce the 3.2 4M41 with VGT for the Montero Sport, Pajero, and Strada; and they will also introduce the 2.5 4D56 with VGT for the Montero Sport and Strada.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
