Results 1,701 to 1,710 of 2048
November 7th, 2017 05:11 PM #1701
November 7th, 2017 07:00 PM #1702
Tingnan mo kung naka engage yung 4x4 gear mo, o baka hindi naka fully engage.
Subukan mong i engage, patakbuhin and then un-engage then patakbuhin mo ulit,
make sure straight yung gulong mo habang nag kakambio.
Matagal talaga mawala yung blink nyan kailangan itakbo para mag fully dis-engage.
- Nov 2017
- 7
November 21st, 2017 01:33 PM #1703Hi Guys, please advice. I bought used 2014 MS GLX AT last weekend. After I got it, I drove to SM Pampanga from Sta.Maria, Bulacan with an Air-con On and heavy traffic in some areas before Bocaue tollgate. The next morning, it got wet by mild short rain and I decided to remove the rain water by using a hose. All the windows are close but when I was cleaning the carpet in front passenger side, I noticed it is wet and when I removed it I found floor carpet in front corner area has lots of water. I called the person I bought this from and he was saying maybe the person who he ask to wash this car left the window open that could have cause this. I am worried it might be an air-con problem because I didn't get a chance to check it after driving from Pampanga nor inspect it before buying
. If this is truly an air-con problem, is this a common issue with MS? Any idea how much would I spend for this issue?
- Jul 2009
- 3,604
November 21st, 2017 01:41 PM #1704
- Nov 2017
- 7
November 27th, 2017 06:17 PM #1706
November 28th, 2017 02:17 AM #1708
Mas maganda yata na nic ay John Galt. Hehehe.
May device ba sir na makakapag test kung tama pa ang rpm na binibigay nung aux fan? Per suking aircon shop, mine is still ok, dont know if its just a visual observation, and not on technical evaluation. Dagdag gastos kasi pag nagpalit ako ng fan dahil naka schedule na rin ako ng replacement ng timing belts. TIA sa mga advise mga tsips!
- Dec 2017
- 1
December 19th, 2017 09:09 AM #1709
December 19th, 2017 09:36 AM #1710
^ It didn't happen to me exactly what was described above but that Sounds like you need to replace your Inhibot switch. It Cost me about 4.5k ata w/ labor if memory serves me right.
Sandali lang ginawa. Mas matagal pa iyong antay sa pagkuha ng switch galing sa bodega at pag antay sa pag bakante ng mekaniko
when you look into the abyss, the abyss looks into youLast edited by baludoy; December 19th, 2017 at 09:53 AM.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
