Results 1,181 to 1,190 of 2048
- Jul 2005
- 430
June 5th, 2014 09:27 AM #1181Umiliaw yung abs warning indicator ko a couple of weeks ago and sarili namang nawala. Ngayon ko lang na-iscan with my bt OBD2 and eto ang lumabas:
My suspicion is either nakutkot ng daga (as pointed out by sir zix) or nadumihan yung sensor nung nadaan ko sa putikan a few weeks back. Saan ko ba dapat ipa-check ito, sa casa where I purchased my Monty (Citimotors Makati) or sa casa where I have my regular PMS (Diamond QA)? Kailangan ko pa rin bang magpa-appointment and mag-hintay ng matagal just like in regular PMS? First time ko lang kasi to avail of warranty.
Btw, is it ok to tell the SA na I scanned my Monty at home using my own scanner? Di na kasi naka-ilaw yung warning light.Last edited by garci; June 5th, 2014 at 09:33 AM.
- May 2014
- 28
June 5th, 2014 10:10 AM #1182Good day mga boss! Napalitan na yung SCV under warranty dahil sa hirap humatak at mabagal na acceleration. Pero hindi pa rin umayos ang acceleration ng monty. Slight improvement lang. Hirap pa rin umabot sa 2k rpm yung monty at from a dead spot, kahit anong apak, walang malakas na pull. May iba pa kayang sira?
Anyway due na rin for 20k pms pero wala pa ako budget. TIA
June 5th, 2014 10:54 AM #1183
June 5th, 2014 01:42 PM #1184
Naku sir baka sa battery na yan di kaya? Try mo sir mag pa check outside casa.
June 5th, 2014 01:51 PM #1185
Good day! 9 months palang monty ko pero 3 beses na nadischarged ang battery niya, frequent ko naman lagyan ng distilled water. Normal lang po ito?
Posted via Ay****
- May 2013
- 142
June 5th, 2014 02:04 PM #1186
- Jul 2010
- 844
June 5th, 2014 03:14 PM #1187Question lang mga ka monty, may nakaexperience na ba na kumakalansing sa bandang harap ng monty natin pag dumadaan sa unpave roads? Di ko madistinguish kung sa dash area o sa tires. Para syang nagvvibrate eh.
Posted via Tsikot Mobile App
June 5th, 2014 03:36 PM #1188
Try other shops that do overhauling of rack and pinion to compare the quality of their work over the previous shop. If it leaks again, then maybe it is better to buy a replacement part instead of overhauling. There are parts that would be better off replaced than overhauled.
June 5th, 2014 07:09 PM #1189
IMO, sa tingin ko po hindi. Either my problema na yun battery or my problema e yun alternator. I suggest na dalhin nyo sa casa for them to check since 9 months pa lang unit nyo. Kindly update us na lang po the result.
Yun battery ng monty ko e once ko lang po nagalaw since we acquired the car.
- May 2014
- 28
June 5th, 2014 09:59 PM #1190Sir, yung uncle ko nagdala sa casa. Hindi ko alam kung ginawa yung SIQL. Sabi pinalitan under warranty pero bakit may charge na 6000pesos? 1st time namin mag claim ng warranty pero ang alam ko dapat free lahat pati labor? Nagulata ako sa charge pero di na lang ako kumibo sa uncle ko. Pero ang malala, wala naman nangyaring mganda. Tulong po!
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
