Results 1 to 10 of 15
May 7th, 2009 05:41 AM #1
[SIZE=4]1st Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Also called[/SIZE][SIZE=2]Chrysler Valiant Lancer[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Dodge Colt[/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1973–1979[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]2-door sedan[/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]5-door station wagon[/SIZE][SIZE=2]3-door hatchback (Celeste)[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]FR layout[/SIZE][SIZE=2]Engine(s)[/SIZE][SIZE=2]1.2 l I4[/SIZE][SIZE=2]1.6 l I4[/SIZE][SIZE=2]1.4 l I4[/SIZE][SIZE=2]2.0 l I4[/SIZE][SIZE=2]Designer[/SIZE][SIZE=2]Shinichi Yamamura (design)[/SIZE][SIZE=2]Munechika Namba (engineering)[2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]The Lancer (LA series in Australia, where it was called the Chrysler Valiant Lancer initially) was first launched in 1973 and proved to be particularly successful in rallies, a claim that it retains to this day. At the time of its launch, Mitsubishi had the Minica kei car and the compact Galant, so the Lancer served to fill the gap in the small to lower-medium segment of the growing Japanese market. Twelve models were launched, ranging from a basic 1.2 L sedan to a more powerful rally-derived 1600 GSR model.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]There were three body styles, 2-door coupes, 4-door sedans, and a rarely seen 5-door station wagon.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Celeste[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]1980 LC Lancer[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1975, the Lancer was complemented by a hatchback coupé called the Mitsubishi Lancer Celeste (also called the Mitsubishi Celeste or Colt Celeste in some markets; it was the Chrysler Lancer Coupé in Australia and the Plymouth Arrow in the United States), and sold with 1.4 L and 1.6 L options (a 2.0 L model was added later). [/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Facelift and exports[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]A facelifted Lancer followed soon after, called the LB series in Australia (and without the Valiant tag). It was this series that emerged in the United States as the Dodge Colt for the 1977 model year, taking over from a badge-engineered Mitsubishi Galant from the previous year. It was offered for one more model year before the Dodge Colt name was transferred to the front wheel drive Mitsubishi Mirage.[/SIZE]
May 7th, 2009 05:42 AM #2
[SIZE=4]2nd Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Second generation[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1979–1988[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]FR layout[/SIZE][SIZE=2]Engine(s)[/SIZE][SIZE=2]4G62 1.8 L SOHC Turbo I4 165 PS 163 hp/121 kW[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]4G33 / 4G12 1.4 L SOHC I4[/SIZE][SIZE=2]4G32 1.6 L l4[/SIZE][SIZE=2]4G11 1.2 L l4[/SIZE][SIZE=2]4G63 2.0 L OHC Turbo l4 168 hp/121 kW (EX 2000 Turbo)[/SIZE][SIZE=2]Transmission(s)[/SIZE][SIZE=2]4-speed manual[/SIZE][SIZE=2]5-speed manual[/SIZE][SIZE=2]Automatic (1400/1600 - GL/XL, 1800 SE )[/SIZE][SIZE=2]Wheelbase[/SIZE][SIZE=2]2,440 mm (96.1 in)[/SIZE][SIZE=2]Length[/SIZE][SIZE=2]4,230 mm (166.5 in)[/SIZE][SIZE=2]Width[/SIZE][SIZE=2]1,620 mm (63.8 in)[/SIZE][SIZE=2]Height[/SIZE][SIZE=2]1,380 mm (54.3 in)–1,390 mm (54.7 in)[/SIZE][SIZE=2]Curb weight[/SIZE][SIZE=2]1,170 kg (2,600 lb)–1,295 kg (2,850 lb)[/SIZE][SIZE=2]Fuel capacity[/SIZE][SIZE=2]50 L (13 US gal; 11 imp gal)[/SIZE][SIZE=2]Designer[/SIZE][SIZE=2]Aldo Sessano (design)[/SIZE][SIZE=2]Rakuzo Mitamura (engineering)[2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1979, the Lancer EX was unveiled in Japan. Two engines were only offered back then, a 1.4 L MCA-JET equipped engine paired with Mitsubishi's Silent Shaft Technology, which generated 80 hp (60 kW) and a 1.6 L engine that generated 85 hp (63 kW) and 100 hp (75 kW). The MCA-JET system was something new than the used carburetor system. The MCA stands for Mitsubishi Clean Air which meant that the EX passes both Japan and US emission standards whilst the new cylinder head design of the engine gave way for a third or Jet valve that introduces an extra swirl of air to the combustion chamber swirling the fuel-air mixture for a cleaner, efficient and thorough burn. Another new breakthrough in the Lancer is the Silent Shaft Technology which is actually two counterbalancing shafts that rotate in opposite directions, cancelling the power pulses a normal 4 cylinder engine would be inherent back then, reducing engine noise and vibration providing a smoother ride. The 1.8 L Sirius 80 engines was then introduced in the Lancer in 1980, along with a new 70 hp (52 kW), 1.2 L engine a year after providing a wider choice of engines for the Lancer. Also, a turbocharged, 135 PS (133 hp/99 kW) engine was added in 1980 for a sportier performance and an Intercooler system was integrated in the existing turbocharged engine to produce 165 PS (163 hp/121 kW) in 1983.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Lancer EX 1800GSR and GT Turbo[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1980, The Lancer EX was introduced with a 1.8 L turbocharged 4-cylinder option known as the 1800GSR and GT Turbo. The first generation 1800GSR and GT only came out generating 135 PS (133 hp/99 kW) only not until in 1983 where the Intercooler was introduced that made the 1800GSR Turbo achieve 165 PS (163 hp/121 kW). No other information was found if whether the 1800GT Turbo also had the Intercooler in 1983.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Lancer EX 2000 Turbo[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Rally Version of the Lancer EX 2000 Turbo[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In Europe, the Lancer EX was offered with a turbocharged 2.0 L 4–cylinder engine known as the Lancer EX 2000 Turbo. It was the first Lancer to use the very first 4g63 engine which was then used in succeeding models such as the Mitsubishi Galant VR-4 and the Lancer Evolutions I to IX. It achieved a maximum output of 168 bhp (125 kW) and manages a top speed of125 mph (201 km/h) in less than 15.5 s. A new feature on this model is that it is equipped with ECI or Advanced Electronically-Controlled Fuel Injection which gave the Lancer more power and outstanding fuel economy as it did 23.0 mpg in city driving and 28.8 to 37.2 mpg in highway driving. A rally version of the Lancer EX 2000 Turbo was made for the 1000 Lakes Rally that gave 280 PS (276 hp/206 kW).[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Philippines[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In The Philippines, the Lancer EX (which is popularly known as the Box Type Lancer) was offered with three variants. These variants are the SL, GSR, and GT. The Lancer SL was the base model with either a 1.2 L engine that generated 70 hp (52 kW) and the MCA-JET 1.4 L engine that generated 80 hp (60 kW) . The GSR was equipped with a 1.6 L engine that generated 100 hp (75 kW) with 5 speed transmission and 4 wheel disc brakes. A 1.8 L option was then available for the GSR. The GT had the 1.6 L engine that also generated 100 hp (75 kW) (there were instances that Turbochargers were also introduced as standard option with the GT) with 5 speed transmission, 4 wheel disc brakes as standard kit and wore the Lancer EX turbo front airdam and rear spoiler. All engines were equipped with the Silent Shaft Technology (the SL had the 1.4 L MCA-JET engine) and soon after, Automatic was available for SL and GSR variants.[/SIZE]
May 7th, 2009 05:44 AM #3
[SIZE=4]3rd Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Third Generation[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Also called[/SIZE][SIZE=2]Mitsubishi Champ[/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1982–1987[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]3-door hatchback[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]5-door hatchback[/SIZE][SIZE=2]5-door station wagon[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]Front engine, front-/four-wheel drive[/SIZE][SIZE=2]Engine(s)[/SIZE][SIZE=2]1.6 L I4[/SIZE][SIZE=2]1.8 L I4 diesel[/SIZE][SIZE=2]Related[/SIZE][SIZE=2]Mitsubishi Mirage[/SIZE][SIZE=2]Proton Saga[/SIZE][SIZE=2]Proton Iswara[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]1987 Mitsubishi Lancer Estate[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Dodge Colt 3-door (US)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1982, a new model was launched called the Lancer Fiore also know as third version, based on the Mitsubishi Mirage. The Fiore was often sold as a Lancer in international markets, but also the Mirage Sedan and, with the five-door hatchback model, remained in production for a good part of the 1980s. In Australia, it would eventually be sold as the Mitsubishi Colt Sedan. Thus, Mitsubishi had two similarly sized models competing in the same market segment.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]The following year, both Mirage and Lancer lines were renewed from the third generation. The Mirage four-door and Lancer sedan became the same car. Fuel injected and turbocharged models were an integral part of this range. A station wagon was added in 1985, and it spawned a raised, four wheel drive version. Often, the Mirage (or Colt) would be the name used on the three-door hatchback, and the Lancer name used on the remainder.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]This model formed the basis of the original Proton sedan, the Saga, Malaysia's first car, which was still in production until early 2008.[/SIZE]
May 7th, 2009 05:46 AM #4
[SIZE=4]4th Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Fourth Generation[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1988–1992[/SIZE][SIZE=2]Successor[/SIZE][SIZE=2]Mitsubishi Carisma (Europe)[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]3-door hatchback[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]5-door hatchback[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]Front engine, front-/four-wheel drive[/SIZE][SIZE=2]Wheelbase[/SIZE][SIZE=2]2,455 mm (96.7 in)[/SIZE][SIZE=2]Related[/SIZE][SIZE=2]Mitsubishi Mirage[/SIZE][SIZE=2]Mitsubishi Chariot/Space Wagon/Expo[/SIZE][SIZE=2]Dodge/Plymouth Colt[/SIZE][SIZE=2]Eagle Summit[/SIZE][SIZE=2]Eagle Vista[/SIZE][SIZE=2]Designer[/SIZE][SIZE=2]Masaru Furukawa (design)[/SIZE][SIZE=2]Yasukichi Akamatsu (engineering)[2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1988, a more aerodynamic-looking Lancer was launched, following the shape of the Galant. A five-door hatchback was added to the range. The Mirage and Lancer nomenclature continued. The station wagon continued on the old platform and shape, as did, in some markets, a five-door version of the Mirage. In Australia, all models were sold as the Mitsubishi Lancer, initially designated as the CA series and from 1990 as the CB. By that time, the Lancer name was shared with the Dodge Lancer sold in North America. The sedan was sold as the Mirage Aspire in Japan.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In some markets a 'van' model was produced, being the three-door hatchback (which had an upright profile) without rear side window (this triggered a reduced sales tax burden in the Dutch market).[/SIZE]
May 7th, 2009 05:47 AM #5
[SIZE=4]5th Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Fifth Generation[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Also called[/SIZE][SIZE=2]Mitsubishi Super Lancer[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1991–1995[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]2-door coupe (Mirage based)[/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]5-door station wagon[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]Front engine, front-/four-wheel drive[/SIZE][SIZE=2]Engine(s)[/SIZE][SIZE=2]1.3 L SOHC I4[/SIZE][SIZE=2]1.5 L SOHC I4[/SIZE][SIZE=2]1.5 L DOHC[/SIZE][SIZE=2]1.8 L SOHC I4[/SIZE][SIZE=2]1.8 L DOHC[/SIZE][SIZE=2]1.6 L DOHC MIVEC I4[/SIZE][SIZE=2]1.8 L DOHC Turbo I4[/SIZE][SIZE=2]Transmission(s)[/SIZE][SIZE=2]4-speed automatic[/SIZE][SIZE=2]5-speed manual[/SIZE][SIZE=2]Wheelbase[/SIZE][SIZE=2]2,500 mm (98.4 in) (sedan)[/SIZE][SIZE=2]2,440 mm (96.1 in) (coupe)[/SIZE][SIZE=2]Related[/SIZE][SIZE=2]Mitsubishi Lancer Evolution[/SIZE][SIZE=2]Mitsubishi Carisma[/SIZE][SIZE=2]Mitsubishi Mirage[/SIZE][SIZE=2]Mitsubishi Chariot/Space Wagon/Expo[/SIZE][SIZE=2]Dodge/Plymouth Colt[/SIZE][SIZE=2]Eagle Summit[/SIZE][SIZE=2]Eagle Vista[/SIZE][SIZE=2]Proton Wira[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]It was only in 1991 that there was greater differentiation between the Mirage and Lancer. Although both were on the same platform, the Lancer sedan received different sheetmetal from the Mirage four-door. The Mirage variant was sold in North America under the Eagle Summit name. Minivan models, such as the Mitsubishi Space Runner and Mitsubishi Chariot, were mechanically related. In 1993, the Lancer wagon, named the Libero in Japan, was launched. An electric version was also released named the Libero EV that ran on NiCd batteries. A V6 variant was also introduced with only 1.6 L, making it the smallest mass-produced V6. The high-performance, turbocharged GSR version formed the basis of the contemporary Lancer Evolution (or 'Lancer Evo') from September 1993, using the drivetrain of the successful Galant VR-4 rally car.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]The Mirage Asti Coupé in Japan was offered as the Lancer Coupé in many export markets.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]The fifth generation Lancer was rebadged as the Proton Wira sedan and 5-door hatchback models in Malaysia in 1993 with 1.3, 1.5, 1.6 and 1.8 L engine capacities. A short-lived 2.0 L diesel model was also available. Currently, the car has stopped production as one of the longest running Proton models in Malaysia after Proton Saga, which is also based on a previous Lancer model. The Proton Wira was recently replaced by Proton's latest model, the Proton Persona.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Australia (1992–1996)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In Australia, this generation was officially referred to as the CC series [3]. It was sold as a 2-door coupe, as well as a 4-door sedan, wagon and 5-door hatchback (essentially carried over from the previous generation). The GL trim model was the last Lancer to use a carburetor engine. The rest of the range used an EFI engine. This generation was sold until 1996, when it was replaced by the popular CE series model.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Model and trim levels:[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]GL - 2-door coupe, 4-door sedan and station wagon. Powered by a 1.5 L engine (67 kW)[/SIZE][SIZE=2]GLXi - 2-door coupe, 4-door sedan and wagon. Powered by a 1.8 L engine (4G93 SOHC - 86 kW) (sold from new with 1.8 instead of 1.6 variant, due to Australia's poor quality "91 octane" fuel)[/SIZE][SIZE=2]Executive - 4-door sedan and wagon. Powered by a 1.8 L engine (4G93 SOHC - 86 kW)[/SIZE][SIZE=2]GSR - 4-door sedan. Powered by a turbocharged 1.8 L engine (4G93t DOHC - 141 kW)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Philippines (1992-1996)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Described as "Lancer itlog"/Lancer egg (also known as Lancer hotdog type), because of the shape of its body and its rear signal light.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Model and trim levels[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]EL - 4-door sedan. Powered by a 1.3 L Cyclone Variable Venturi carbureted engine (4G13 SOHC) (59 kW)[/SIZE][SIZE=2]GLi - 4-door sedan. Powered by a 1.5 L Cyclone ECI-MULTI engine (4G15 SOHC) (66 kW)[/SIZE][SIZE=2]GLXi - 4-door sedan. Powered by a 1.6 L Cyclone ECI-MULTI engine (4G92 SOHC) (86 kW)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]EX - 4-door sedan. Same specifications as the EL, and released in 1996.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Europe (1992–1996)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Model and trim levels:[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]GL - 4-door sedan and wagon. Powered by a 1.3 L ECI-MULTI engine (4G13 SOHC) (55 kW)[/SIZE][SIZE=2]GLXi - 4-door sedan and wagon. FWD or AWD. Powered by a 1.6 L ECI-MULTI engine (4G92 SOHC) (84 kW)[/SIZE][SIZE=2]GTI -(gera from over there) 4-door sedan. Powered by a 1.8 L ECI-MULTI engine (4G93 DOHC) (103 kW)[/SIZE]
May 7th, 2009 05:48 AM #6
[SIZE=4]6th Gen[/SIZE]
[SIZE=4][/SIZE]
[SIZE=2]Sixth Generation[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Production[/SIZE][SIZE=2]1995–2000[/SIZE][SIZE=2]Body style(s)[/SIZE][SIZE=2]2-door coupe[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]4-door sedan[/SIZE][SIZE=2]4-door station wagon[/SIZE][SIZE=2]Layout[/SIZE][SIZE=2]Front engine, front-/four-wheel drive[/SIZE][SIZE=2]Engine(s)[/SIZE][SIZE=2]1.5 L SOHC I4[/SIZE][SIZE=2]1.8 L SOHC I4[/SIZE][SIZE=2]1.8 L DOHC Turbo I4[/SIZE][SIZE=2]Transmission(s)[/SIZE][SIZE=2]4-speed automatic[/SIZE][SIZE=2]4-speed semi-auto[/SIZE][SIZE=2]5-speed manual[/SIZE][SIZE=2]Wheelbase[/SIZE][SIZE=2]2,500 mm (98.4 in) (sedan)[/SIZE][SIZE=2]2,440 mm (96.1 in) (coupe)[/SIZE][SIZE=2]Related[/SIZE][SIZE=2]Mitsubishi Lancer Evolution[/SIZE][SIZE=2]Mitsubishi Carisma[/SIZE][SIZE=2]Volvo S40[/SIZE][SIZE=2]Volvo V40[/SIZE][SIZE=2]Mitsubishi Mirage[/SIZE][SIZE=2]Mitsubishi Chariot/Space Wagon/Expo[/SIZE][SIZE=2]Dodge/Plymouth Colt[/SIZE][SIZE=2]Eagle Summit[/SIZE][SIZE=2]Soueast Lioncel[/SIZE][SIZE=2]Proton Waja[/SIZE][SIZE=2]Proton Persona[/SIZE][SIZE=2]Proton Gen2[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In 1995, the Lancer was renewed for its sixth generation, building on the earlier model's format. Apart from the Evo models' continuation, it did not depart from the established Lancer formula. A sedan and wagon (Libero in Japan) were offered, with a related Mirage model. The coupé continued as the Mirage Asti in Japan, known as the Lancer Coupé elsewhere. The 1995 Lancer (Model from 1995-2002 in some countries) is more popularly known as the 1997 Lancer. A turbocharged GSR version continued to be sold until the end of the 1990s. This platform was also the basis for the Mirage, as it was known in North America and various other markets.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]From 1996-2004, the Mitsubishi Carisma replaced the Mitsubishi Lancer in some markets.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]It is of note, that the Lancer Evolution V was the only Lancer Evolution to gain Mitsubishi the WRC constructors championship. However, driver Tommi Makinen was able to claim four WRC driver's championships for himself, in 1996-1999, driving Mitsubishi's Lancer Evolution III, IV, V & VI.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][edit] Australia (1996–2004)[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]In Australia, the sixth sold from 1996-2004. It was designated as the CE series. Like the previous generation, it was available in a variety of body styles, which helped to cater for a more broad audience. The introduction of a sporty MR coupe helped to target this model directly towards a younger audience. The station wagon continued on as a CE model, even though it was essentially carried over from the previous generation. This model had an unusually long model run, becoming increasingly uncompetitive as the years went by and often heavily discounted by dealers. Towards the end of its model run, Mitsubishi introduced some limited edition models (based on the GLi) to remain competitive with its rivals, these editions featured extras such as sports interiors, alloys and body kits off higher spec models. Generally, this generation sold well throughout its production run.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]It should be noted that despite the introduction of the eighth generation Lancer Cedia in 2002, the CE series continued to be sold alongside it until mid-2004. The sedan was available in GLi trim, until it was finally discontinued in 2003. The coupe was facelifted and now only available in GLi and MR trims.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]Due to its appearance, affordability, and the rise in status of the Lancer Evolution, this generation was quite popular with young car enthusiasts and the aftermarket modified Japanese car scene. Some popular modifications include exhaust systems, suspension, after market stereos and replica Evolution body kits.[/SIZE]
May 7th, 2009 05:49 AM #7
[SIZE=4]MODELS AND TRIM LEVELS[/SIZE]
[SIZE=4][/SIZE]
[SIZE=5]Series I (96-98) and Series II (98-99)[/SIZE][SIZE=5][/SIZE][SIZE=5][/SIZE][SIZE=2]GLi - 2-door coupe and 4-door sedan. Powered by a 4 cylinder, 1.5 L engine (4G15 SOHC - 69 kW)[/SIZE][SIZE=2]GLXi - 2-door coupe and 4-door sedan. Powered by a 4 cylinder, 1.8 L engine (4G93 SOHC - 88 kW)[/SIZE][SIZE=2]MR - 2-door coupe. Powered by a 4 cylinder, 1.8L engine (4G93 SOHC - 86 kW)[/SIZE][SIZE=2]MR - 4-door coupe. Powered by a 4 cylinder, 1.6L MIVEC engine (4G92 DOHC - 130 kW)[/SIZE][SIZE=2]GSR - 4-door sedan. Powered by a turbocharged 1.8 L engine (4G93t DOHC - 141 kW)[/SIZE][SIZE=2]MXd - 4-door sedan. Powered by a Diesel Turbocharged 2.0L engine (4D68T SOHC - 65 kW)[/SIZE]
May 7th, 2009 05:52 AM #8
[SIZE=6]MODELS AND TRIM LEVELS[/SIZE]
[SIZE=5][/SIZE][SIZE=5]Series III (99-03)[/SIZE][SIZE=6][/SIZE][SIZE=6][/SIZE][SIZE=6][/SIZE][SIZE=2]GLi - 2-door coupe (1.5 L or 1.8 L) and 4-door sedan (4 cylinder, 1.8 L)[/SIZE][SIZE=2]GLXi - 2-door coupe and 4-door sedan. Powered by a 4 cylinder, 1.8 L engine[/SIZE][SIZE=2]MR - 2-door coupe. Powered by a 4 cylinder (6 cylinder, 99-00), 1.8 L engine[/SIZE]
[SIZE=5][/SIZE][SIZE=5]Series IV (02-04) coupe update only[/SIZE][SIZE=6][/SIZE][SIZE=6][/SIZE][SIZE=2]GLi - Choice of 1.5 L engine (discontinued in 2003) or 1.8 L engine, 4 Cylinder[/SIZE][SIZE=2]MR - Powered by a 1.8 L engine, producing 86 kW (115 hp) & 163 N·m (120 lb·ft) of torque (1500-4500 rpm) out of a 4 cylinder[/SIZE]
[SIZE=5][/SIZE][SIZE=5]Philippines (1996–2002)[/SIZE][SIZE=2]Described as "Lancer Pizza" such for their pizza-shaped rear lamps.[/SIZE][SIZE=2][/SIZE][SIZE=2][/SIZE][SIZE=2]EL - 4-door sedan with 1.3 L carb engine (4G13 - 55 kW)[/SIZE][SIZE=2]GL - 4-door sedan with 1.5 L engine (4G15 - 65 kW)[/SIZE][SIZE=2]GLXi - 4-door sedan with 1.6 L SOHC engine (4G92 - 85 kW)[/SIZE][SIZE=2]GLX - 1999-2002 model 4-door sedan with 1.5 L carb engine[/SIZE][SIZE=2]GLS - 1999-2002 model 4-door sedan with 1.6 L Fuel injected engine[/SIZE][SIZE=2]MX - 1999-2002 model 4-door sedan top of the line with 1.6 L EFI SOHC engine with INVECS automatic transmission.[/SIZE][SIZE=2]GSR - 2-door coupe (97-02) Powered by 1.6 L 4G92 SOHC engine[/SIZE]
May 23rd, 2009 02:37 AM #9
[SIZE=4]Seventh Generation[/SIZE]
Seventh GenerationProduction2000–presentPredecessorMitsubishi Carisma (Europe)
Mitsubishi Mirage (USA)Body style(s)4-door sedan
4-door station wagonLayoutFF layoutPlatformCS7AEngine(s)4G13 1.3 L SOHC
4G18 1.6 L SOHC
4G93 1.8 L DOHC I4
4G94 2.0 L SOHC I4
4G63 2.0 L DOHC
4G69 2.4 L SOHC MIVEC I4Transmission(s)4-speed automatic
4-speed semi-auto
5-speed manual
invecs III CVTWheelbase2,600 mm (102.4 in)Length4,495 mm (177.0 in)-4,605 mm (181.3 in)Width1,695 mm (66.7 in)Height1,375 mm (54.1 in)-1,425 mm (56.1 in)RelatedMitsubishi Lancer Evolution, Mitsubishi Outlander
2002-2003 Mitsubishi Lancer (US)
2006 Mitsubishi Lancer Ralliart sedan (North America)
The year 2000 saw the release of the seventh-generation Lancer Cedia in Japan (meaning - Century Diamond); though in most markets the seventh generation Lancer continued, built at Mitsubishi's Mizushima plant in Japan. The new model was available in sedan and station wagon forms. The Mirage, apart from the export models, became a different car in Japan that was unrelated to the Lancer. In Europe, the Lancer was not offered in some countries, being too close to the size of the Dutch-built Carisma, so the Evo VII model sold there bore the Carisma name. This is the first generation in many years where the Lancer nameplate is universally used. It is still sold in Japan where the eighth generation Lancer is known as Galant Fortis
In North America, the Lancer Cedia was introduced in 2002 as a direct replacement for the Mirage. It is powered by a 2.0 L 4G94 engine producing 120 hp (89 kW) and 130 ft·lbf (176 N·m) of torque.
In Australia, the seventh generation Lancer was introduced as the CG series in July 2002 with the 2.0 L 4G94 engine. It was introduced as a replacement for the seventh generation sedan, and was sold alongside the popular seventh generation coupe.
[edit] Ralliart
In addition to the facelift, North America received two additional models to the Lancer line in 2004 - Sportback and Ralliart. The latter slated in between the base and high performance Evolution model. Both the Sportback and Ralliart had high levels of equipment, based on the Australian Lancer VR-X. The main difference being that these cars came equipped with Mitsubishi's 2.4 L4G69 engine (rated at 160 hp (119 kW)/162 ft·lbf for the Sportback, and 162 hp (121 kW)/162 ft·lbf for the Ralliart), included a new, stiffer suspension package that improved handling and lowered the cars stance by 1 centimeter, 16" alloy wheels, front bucket seats borrowed from Japan's Mitsubishi Evolution GT-A, Fog Lamps, and a new aerodynamic ground package. The Ralliart also came equipped with a cosmetic rear deck spoiler, and clear rear tail lights. The Sportback was equipped with a 4-speed INVECS-II automatic transmission, with no option for a manual transmission, while the Ralliart came with a 5-speed manual transmission with an option for the 4-speed automatic. The Sportback was also available in the lower spec LS trim.
Due to Mitsubishi's deteriorating financial situation and slow sales, the Lancer Sportback wagon was cancelled in the United States one year after its release.
[edit] Other markets
In Japan, the Lancer Cedia was offered with many different trim levels and engines, including options which were never seen in export markets. It was also one of the first models to use the INVECS-III CVT transmission. There was also a Ralliart version of the sportswagon which was powered by a turbocharged 1.8 L GDI engine. As of 2007, the seventh generation Lancer sedan is still being sold alongside the new eighth generation, which is known in the home market as the Galant Fortis.
In Pakistan, this variant was launched in 2005 with cosmetic changes from the front and the back. Thai production was switched to the new model, and in all markets except for India the seventh-generation model was no longer marketed, four years after the Cedia's introduction.
India received the new Lancer in 2006, known locally as the Mitsubishi Cedia to distinguish it from this version that is still assembled and sold as the Lancer because of its continued popularity.
In some European markets, the Lancer began to take the place of the Carisma in 2004. It is powered by a 1.3 L SOHC 4G13, 1.6 L SOHC 4G18 engine and a 2.0 L DOHC 4G63 (all 4-cylinder).
In Malaysia, the Lancer was made available after Mitsubishi had sold all its shares in Malaysian carmaker Proton, marking the return of Mitsubishi in Malaysian market after being absent since 1985 due to the agreement with Proton. The Lancer sold in Malaysia was powered by the 4G18 engine which also powered the early 1.6 Proton Waja model.
In the Philippines, the Lancer underwent a facelift, now without the central semi-triangle in the grille. It is offered in 2 trims, the base GLX with a 5-speed manual and the GLS with an all-new INVECS-III CVT with manual override. All of them are powered with an l4 1.6L 4G16 SOHC engine
May 23rd, 2009 02:42 AM #10
Eighth generation
Eighth GenerationAlso calledGalant Fortis (Japan)
Lancer Fortis (Taiwan)
Lancer EX (Singapore)
Lancer Serie R (Chile)
Production2007-presentBody style(s)4-door sedan (GS41)
5-door hatchback (GS44S)LayoutFront engine, front-/four-wheel drivePlatformMitsubishi GS platformEngine(s)4B12 2.4 L DOHC MIVEC I4,
4B11 2.0 L DOHC MIVEC I4,
4B10 1.8 L DOHC MIVEC I4,
4A91 1.5 L DOHC MIVEC I4,
VW 2.0 L Di-D DieselTransmission(s)5-speed manual (F5MBB)
INVECS-III CVT automatic (F1CJA)
INVECS-II 4-Speed Automatic (Singapore 1.5l variant)
6-speed twin-clutch gearbox (Lancer Ralliart)Wheelbase2,635 mm (103.7 in)Length4,573 mm (180.0 in)
Sportback: 4,585 mm (180.5 in)Width1,760 mm (69.3 in)Height1,490 mm (58.7 in)
Sportback: 1,515 mm (59.6 in)Curb weight1,320 kg (2,900 lb)-1,593 kg (3,510 lb)Fuel capacity59 L (16 US gal; 13 imp gal)RelatedMitsubishi Lancer Evolution Mitsubishi Outlander
In 2005, Mitsubishi revealed the Concept-X model car at the Tokyo Motor Show and its Concept-Sportback model at the Frankfurt motor show. The new Lancer is based on these two concepts. The new Lancer was officially revealed in January 2007 at the Detroit Motor Show and went on sale in North American markets on March 2007 as a 2008 model. New Lancer features Mitsubishi's next-generation RISE safety body.
[edit] North America
For the United States, the new Lancer was initially available in DE, ES, and GTS trim levels.[7] DE and ES are powered by a GEMA based 4B11, 2.0 liter DOHC engine producing 152 hp (113 kW) (except for California models which have been detuned to 143 hp (107 kW) to meet regulations). Transmission options include a brand new CVT, sourced from Jatco (code: F1CJA), alongside a regular 5-speed manual sourced from Aisin AI (code: F5MBB). GTS models get a 6-speed (fixed gears in sport mode) paddle shift version of the CVT.
In Canada, a fourth model (SE) was introduced to the Lancer lineup late in the model year. The SE model is a cross between the ES and GTS models. It includes the skirt package similar to the GTS, a rear spoiler, and unlike the GTS model, the SE includes a sunroof. Features not included in the SE model that are found in the GTS are the FAST key, Bluetooth hands-free cell phone interface, automatic climate control, Rockford Fosgate sound system, carbon fiber trim pieces, leather wrapped steering wheel and shift knob, and 18" wheels.
2010 Mitsubishi Lancer Ralliart Sportback (North America)
For U.S. markets, starting with the 2009 model year, an ES-Sport version was released similar to the SE model for the Canadian market. Externally the ES-Sport is similar in appaearance to the GTS' skirts, spoiler, mirrors, etc (with the exception of the wheels, the ES-Sport retains the ES wheelset). The ES-Sport also uses the ES 2.0 liter engine.[8]
For 2009, the GTS is powered by a 2.4 L 4B12 engine producing 168hp and 167 lb ft.[8]
Mitsubishi plans on selling the five-door hatchback version, known as the Sportback, in the U.S. for the 2010 model year, starting in late Summer 2009.[9]
[edit] Australia
2008-09 Mitsubishi Lancer VRX
The Lancer was released in Australia in October 2007[10], designated as the CJ series[11]. It will come in ES, VR, VRX and, since the forth quarter of 2008, Aspire trim levels. Active stability control and traction control will be standard on all models. Standard on the ES will be dual front airbags and a driver knee airbag. The VR and VRX will get side and curtain airbags also. It will have a 2 litre 4B11, 113 kW (152 hp) engine and be equipped with a 5-speed manual or with a 6 speed CVT transmission as a $AUD2300 option. A Ralliart model will follow, and a Lancer Evolution will also make the line up. The Lancer also scored a maximum of 5 stars in the ANCAP crash test.[12] As of September 2008, Mitsubishi's Australian website revealed a new trim level called Aspire. A 2.4 litre engine has been introduced for the Aspire along with leather seats, High Intensity Discharge headlights, Rockord-Fosgate premium sound system and CVT as standard. The MMCS entertainment and satellite navigation unit is an option. The VRX has been upgraded with the larger engine. The Lancer Sportback is now available in Australia as of October 2008, the model line up includes ES, VR, VRX and Ralliart.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
