Is it okay with a 235/40/18 tire to run on a 30psi tire pressure?
Uwi kasi ako province bukas mga sir, okay lang ba itakbo yun hanggang pangasinan? Baka kasi kulang ang pressure?
Check the recommended tire pressure on your car's driver-side door or post near the door. Usually yellow sticker yun.
Basta hindi donut yung sidewall you should be ok. If part of the shoulder/sidewall starts to go near the tread malambot na yun masyado.
thats a safe psi sir. but it really depends also on the tires, check ninyo rin ang max psi ng tires ninyo. i have 19's and recommended is 35psi and those are 40 series tires. i have 20's with 50 series tires, recommended is 30 psi.
this is only applicable if the tires and rims used are OEM.
this is not necessarily true sir regarding bigger the tire, lower the pressure. in 4x4, tire pressure will go a bit lower compare to normal if you need more surface bit. but again, depends on the terrain and kind of tires you are using.
Suggest to check the Nitto website as there is a page there discussing the recommended tire pressure. The page is based on the US auto safety board. Usually, the pressure for performance tires are higher compared with the OEMs in order to support the original tire loads.
