Results 1 to 15 of 15
    Jan 2011
    hi po,
    we just bought a 2nd hand car, adventure gls sport. ok naman po siya overall, although as can be expected from a second-hand, there are some concerns that i would like to consult with the experts here. first time kasi to own a vehicle eh so sensya na if some questions seem silly.
    > how do we verify model - 2008 daw yung unit, pero info sa warranty indicates dec. 2007 siya kinuha.
    > we noticed fuel consumption is very high, city driving lang, 2 days empty after full tank - would a calibration fix this?
    > the right signal light stays stuck upon turning - how and where do we go to fix this?
    > cabin interior light is not working - is this just a bulb or electrical issue?
    mileage is 46k - already changed oil and filter. any other recommended checks? and sino/saan reliable and affordable?
    maganda naman po ang takbo. just want to make sure that it is in its best condition especially since my two young daughters will be the primary passengers of the car.
    thanks and more power to everyone here!
    Jan 2011
    Quote Originally Posted by imajne View Post
    hi po,
    Ung model ng sasakyan makikita sa driver side door me plate dun nka indicate ang year model ng sasakyan. kung mataas ang fuel consumption po ninyo ay may marami itong posibleng dahilan, defective ung O2 sensor nyo or MAF sensor, pwede din palyado ang fuel pressure regulator, engine timing ay isa ring issue. interior lighting pwede icheck and fuse n nsa paanan ng driver's compartment, tangaling ung fuse cover at tingnan dun kung alin ang interior fuse kung sira at palitan kung kailangan. Ung air filter napalitan nb, it should be changed every 30,000km
    Jan 2011
    Quote Originally Posted by 650cc View Post
    - thanks sir for the prompt response. can you recommend a shop in Banawe where we can have FC checked - will Betan check and repair these, or calibration lang talaga sila?
    - air filter was cleaned na previously. we will do so after 5k.
    - how about my question about the signal light staying on after a turn?
    thanks for all the help!
    Jan 2011
    Alin po ang icacalibrate ang odometer? wla pong ganun, best po tlaga scan ang pcm nyan pra wlang pong tsambahan ng aayusin at bawat gastos, sory po wla aq mairerekomenda, wla po aq kilala jn i fix cars myself po, mekaniko po aq galing ng saudi, ung turn siganl dapat po palitan ang flasher relay defective n po yn
    Jan 2011
    salamat sir sa tips. yung question po sa calibration - sa threads po kasi,, calibration has been mentioned for diesel engines pag may problem with fuel consumption.
    Jan 2011
    yes tama po kinacalibrate po yn, sory i forgot mitsubishi pla po sau, yup try po to get it calibrated....sory ulit wla po aq kilalang shops
noob questions about 2nd hand mitsubishi adventure
