Results 1 to 18 of 18
    Just curious. Is it possible to convert the existing 4x2 GLX, GLS and GLS V Monteros to 4x4 as an aftermarket modification? If Yes how much will it cost? Thanks.
    Even if it was, it's not worth the hassle IMO. hehe.
    Pero re: the main question, no idea po.
    Jul 2004
    interesting question. i would think it is possible. just like the 4x2 GU patrol, nakaabang na ata ang components sa front wheels for possible 4wd conversion
    the only problem is where can you source the 4wd upgrade kit
    try asking the casa first for a quotation and then search in banawe/evangelista. you can also google 4x4 queries on this
    will ask the service officer of my dealer if can be done
    Jun 2007
    Possible, but Ridiculously expensive....
    Selling the 4x2 and buying the 4x4 version is even more practical IMHO if you really want a 4x4....
    Jun 2007
    tama sir, mas madali yung sa GU patrol....parang plug and play lang sya...actually I saw a 4x4 conversion kit nga before selling for only 50k+ only
    Unlike kasi sa monty...ang daming kadramahan, may mga sensor sensor pa yan na kung ano ano...not to mention the mechanical parts pa to be added....
    Jul 2004
    patrol also has electronic sensors and ECU
    sa montero, its just the same. if you have the TPMS, its already there and will not really be affected
    i can't think of any sensors that will be affected by the conversion
    as for mechanical, well, bubutasan mo ang cabin to make way for the extra stick shift but that is the same with all other 4x2 conversions
    as for the price, well i am not prejudging the cost until i get the quotation for it. mahirap mag conclude na "ridiculously expensive" or "not worth it" until we get the facts on the pesos and cents actual quotation. if you do know the price then perhaps you can post it for the guidance of the TS.
    the price difference between the monty 4x2 model versus the 4x4 model is about P250T conservatively. lets weigh in on the cost based on this
    then let the TS do his own cost-benefit analysis after all it is his budget
    Feb 2005
    Average price difference of a 4x2 vs. 4x4 (off the plant) is between 200-250k.... and this is already considered expensive. And a locoroco stated, doing an aftermarket conversion would be even be worst.... and more than the financial concerns, the inconvenience one would go thru.
    Oh, and if you're to do this to a vehicle that is still under warranty, consider the warranty void the minute you do this.
    Quote Originally Posted by roydok View Post
    Yes it is easy to convert as long as you use OEM materials. But mapapamahal ka kung per piece bili. Better if you can find a wreck 4x4 MS tapos kahuyan mo. I've seen 4x4 pick-ups converted to 4x4, not much difference. Yung mga brakcet kasi at holes nakaabang na yan agad eh.
    Jul 2004
    just got this response from my dealer (talked to their vp of service): the 4wd conversion is not plug and play. you need to change the front wheel hubs and suspension (to handle the heavier load of the added differential)
    front suspension, front differential and transfer case will cost more than P100T (not bad actually if this is all OEM) but he estimates the total cost to be between 20-30% of the vehicle cost. if the brandnew 4x2 monty costs P1.3M then conversion is at P260T * 20% of the vehicle cost, conservatively. considering some cost overruns, perhaps a more conservative budget should be P300T - if you have this done at the casa
    but what drives up this cost beyond P100T he did not specific. perhaps labor? other parts? oil? etc, etc? alam naman natin na sa mga maliliit na bagay rin tumitira yung casa aside from the major parts
    perhaps the TS can do a combination, i.e. get the major OEM parts and the rest aftermarket and have this done by a competent and trusted aftermarket installer
    the comparative cost analysis should be between installing the 4wd kit or selling the 4x2 and getting a brandnew 4x4
    i wish the TS good luck in his query and should he pursue the conversion, do keep us posted for the information and added knowledge of the montero sport community
    Not plug and play but very easy to do since it is part of the design as long nga as you use Oem/oem spec materials. Mahirap kung gamitan nmo ng ibnag transfer case at tranny pa like the expensive ones para maiba.
    But IMO, buy a winch na lang. God enough to pull you aka 4WD.
    Jul 2004
    curiously, i wonder if a 4D56 pajero's 4wd system will fit a montero?
    curiouser still, i also wonder if you can use a 4D56 strada's 4wd for a montero?
    or perhaps some kind of combination of parts?
    i am sure that the above two are more readily available in surplus shops that that of an MS.
    hmmmmm
    Jun 2007
    I'm aware that the patrol has all sensors and those electronic stuff....but having a non commonrail engine, Im putting a big bet on it being a lesser sensitive vehicle when it comes to major mods.
    and yes, I shouldn't have used the word ridiculous (though I really think it is), rather, not worth it is much more fitting for this conversion.
    kung gusto lang naman maglaro ni TS using his 4x2....I'd rather settle for differential lockers at the rear... problema lang wala pa yata available for montero hehe
    Aug 2004
    Extra cash is probably for interior trim (extra shifter) and other modifications. Not bad, as far as conversions go, but absolutely not cost-effective.
    Probably worse if the unit is AT, you'd have to change ECUs, I bet...
    Thank you very much.
    Jul 2004
    ... Better if you can find a wreck 4x4 MS tapos kahuyan mo.
    a good alternative especially if you have the right casa/insurance contacts. i have seen wrecked 4x4s at the casa abandoned by the owners since these were all claimed under insurance already.
    with the right connections, you can actually get these OEM parts cheap
    in the past, i was offered by my nissan casa contact then of a nice set of presidential edition headlights and bumpers of a GU patrol that was rear ended badly and abandoned by the owner. the wrecked patrol was just in the casa gathering dust
    i wonder if the shops in evangelista/banawe would have these parts although kung mga chop chop yan, medyo ma konsensya lang ako sa source, if you know what i mean
Montero 4x2 conversion
