Results 1 to 10 of 10
    Dec 2002
    pansin ko parang mahina ang headlights ng pajero... kapag may street light nawawala na ang ilaw..
    calling all gen 2.5 pajero owners, ganito din ba headlights nyo?
    what bulbs are you using now? originals or the super white HID wannabe's
    Dec 2002
    the bulbs are originals...
    change high wattage bulbs and have it relayed.
    I'm using OEM bulbs with the glass (and not clear lens) headlamp housing. Ok naman ang performance kahit tinted ang windshield (3M magic neutral).
    Dec 2002
    I upgraded mine to 90 watts. the oem is kinda weak for me bec I have tinted front... panther medium. don't forget the relays.
    Mar 2003
    sir, try nyo check ang headlight aim nyo muna. dati, i posted a thread na wer to look for oem foglights kac parang mahina nga yung illumination ng pajero namin. pero nung nalaman ko na sobrang mahal, i checked sa web kung pano mag check ng headlight aim. wen i finally got a diagram on how to focus my lights, it turned out na both headlights wer aimed 2 much 2 d right.dis is y d driver's side of illumination was very weak. ang sobrang liwanag ay yung mga puno sa right shoulder ng NLEX. i jst adjusted both lamps more 2 d left using d diagram i found and d results wer ok. try dis link:
    http://dave.maisenhelder.net/bmw/headlight_aim.htm
    change to raybrigs :D same wattage, high output. all weather pa
    I seem to find those "clear" or crystal headlights to be weaker then the opaque/glass ones IMO...
    You could try toying with the adjustment then add na rin relays and real 90/100w bulbs (not the 55/60 with 90/100 outputs)... it'll be cheaper in the long run. Also, have a good electrical shop do the jopb para sure... i've already experienced bad relay/rewire setups and its really a hassle, especially since you'll usually find out about the problem at night when you're in need of the lights.
    or you can buy the IPF relay harness, yung orig ha. para sure and the warranty on your vehicle will not be void. may sticker yata mga witsu na void ang warranty pag tampered ang wires.
Gen 2.5 pajero, weak headlights?
