GUYS my group b kau sali nmn ako VR 496 model 09178399463 marikina area ako
I had my coolant problem done...it's the water pump assembly daw (P7k), I had it fixed at SFM San Pablo (Mitsubishi Dealer) so can't argue with them. I also had my timing belt replaced (with some pulleys??) so that costs around P18k! Radiator Cap replaced (P750). And it seems I had a problem with my Tranny
. And had my rear brake pads replaced. All in all...P36k! But that's the price you have to pay if you go CASA. But all is running smoothly again. They even fixed my AIRCON UNIT's ticking sound (relay daw un). So no regrets. But Still I have a problem with my car going a wee bit to the right while letting go of the steering wheel. The mechanics says its the TYROD, some says it the Suspsension ball joint. WHat do you think?
I hadn't had that done, since I'm waaay over my budget! But based on what I read here...parang suspension arm nga ang problem. Bigla nga lumakas ang kalampag ng Car ko sa rear..SHOCKS daw needs to be replaced (11k estimated).!! Mahirap tlg magkaroon ng 2nd hand. I had a 99 VR (pating version). It's still a cool car. But the fuel consumption....WAAAAHHH!
Aba! Sounds very familiar ah! My gf's Galant had that ticking sound a few months back. Relay nga daw ang problema. Ginawa na lang ng electrician dinisconnect nya. Ayun, problem solved kaso wala nga lang hangin sa paa (the part of the aircon that blows below the dashboard). Ok naman kasi hindi din naman pansin 'yun eh as long as malamig naman 'yung tumatamang hangin sa upper body pati sa mukha. May kabig din sa kanan 'yung kotse kaya sabi sa akin ball joint daw.
newbie po.. ask ko lang, im considering on buying a 2nd hand 1995 vr4 pero i have no idea kun ok ba yun choice ko,what are the things that i have to consider? tonight na kasi kmi magkikita nun seller.. thanks
I just had it serviced at a Mitsu Casa. They say it's the WATER PUMP ASSEMBLY (that's 7k already!!). What do you think? I already asked the BYPASS HOSE when I went to RAPIDE and they don't seem to know where it is. That's why I left it to the experts at MITSU. The only problem is you're completely under their control and before you know it...your wallet is empty :shocked2:
I tried to have it aligned last 9/29/07 at RAPIDE. Then they told me they cannot bec. of the Tie Rod and Suspension Arm (which I think causes my car to veer to the right when the steering wheel is released). And the estimate...around P25k! Is that justifiable? So I went to other Mechanics. They told me it's only a TIE-ROD problem. Others, the Suspension ARM only. Now who the heck would tell me what the real problem is?![]()
6km/litre CITY DRIVING
9km/litre HIGHWAY DRIVING
Not bad for it's class. This drastically changes when u don't use your aircon (remember 70% of fuel is consumed by the A/C). And of course the TRANNY. If you're going for the Manual Tranny then it's less consuming than the A/T.![]()
GUYS im selling my VR4 black 17 inch mags concept one spider falken tires
sound set up 0917 8399463 9416349 very fresh check my friendster marky_1029*hotmail.com andun pix very fresh makinis wala kalampag
yung sa relay ko parang pinasa nila sa HEATER...since di ko naman daw gagamitin un (nga naman, wala naman tayo snow eh). my aircon is the digital one. about sa kabig ko sa kanan, I'm still hesitant. Tie-rod, suspension arm, ball joint or all of the above?? Alin nga kaya ang problem. Someone out there got tips for me?
Dinala namin sa Zee yung Galant para ipacheck suspension. Medyo malakas na kabig sa kanan pati maalog na kahit konting lubak. Daming papalitan eh pero siguro it's about time kasi since pagkabili ng Galant wala pang pinapalitan sa suspension system. Ang estimate 8,080 - the whole works plus fries on the side. Pinagawa na namin kasi mahirap na baka sa daan pa abutin ng problema. Sa Cruven sana namin dadalhin mas malapit sa amin ang Zee. Tomorrow makukuha na namin yung Galant. I'll post kung okay naman ang gawa nila pero with what I've read and heard about Zee's suspension jobs, pulido daw talaga.
Sirs, I have a question... I'm planning to buy a '96 VR4, is it true na mausok daw ung muffler? Not sure kung true ung sinsasabi nung kakilala ko. Thanks in advance!
