Originally Posted by
rion
big doesn't always mean better. on 4d56t's case it will only make your ride more like a "big snail" on start off...
you are still limited to your engine's boost pressure max capacity, which is 12psi.
one best way is to use those Variable geometry turbo. the turbo internal space size varies according to your rpm. but work and cost is not worth the trouble...
the real best way is to use your existing turbo and buy a boost controller to increase boost. and for better turbo lifespan, add a BOV.
