Sirs up ko lang po yung tanong ko. Anyone used semi-synthetic lang on their monty's? Degraded ba ang performance if semi-syn lang? Does it really require 100% synthetic oil?
Guys i'm nearing my 5k check up. Torn between caltex delo 400, mobil delvac MX, and petron trekker. All i believe are mineral oils. Not interested using fully synthstic since i'm into 5000 kms change oil intervals.
Anu pinaka OK? Thanks!
Has anyone tried using the baldwin oil filter with just semi-synthetic or mineral oil on their monty engines and changing it every 10k?
basically sir ganito ang alam ko na set up kasi medyo confusing na ngayon ang classifications ng oil, para mas ok i-base natin by group and refining and viscosity
group II ( viscosity 80-120) Hydro-processed:
group II + Hydrocracking involed:
group III ( viscosity 120> ) Severely hydro-processed:
group III+ Very high viscosity index oils/highly refined:
group IV ( ) Oligomerization:
if im not mistaken DELO are under group II +, same with mobil delvac MX...
sir jmtyper, thanks sa reply.Originally Posted by jmtyper
sir miko, thanks sa reply. although mechanic ang name ko, hindi ako experts pagdating sa mga oil. given the group, ano po yun pinaka best group sa monty natin? as of now, im using the mobil delvac MX and planning to use the Delo 400 sa 5000 PMS ko. Im planning not to use FS since every 5000km e gusto ko lagi na mag change oil para lagi malinis yun langis ko. Kindly enlighten naman po ako if im doing the right thing. TIA
and isa pa po, diba pagtaas ng viscosity the better, correct me if Im wrong na lang po. Thanks.
