if you want to convert your gen. 2 pajero to a euro ver. pajero,what are the parts/accesories that you need for the conversion?what to add ro change,thanks
Where in Europe? UK versions were called 'Shoguns'. Spain called them 'Montero'.
Generally:
*European rear plate holder (the one that slants the plate upwards)
*Black door handles, mirrors, grille, bumpers, key holes, and window trim (though some Euro markets did get brightwork as standard)
*Euro rear lamp. Bumper mounted tail/stop and turn signals. Body mounted rear fog lamp (functional on driver's side only) with reverse lamp and dummy lenses (where the upper taillamp and old reverse lamp resided)
*Monotone was also popular in Europe
Isip pa ako.
here's a euro-setup gen2 pajero (the red one) from JeF of mymitsuph:
couldn't find other pics of JeF's ride though...
i wonder if some irish guy living in the south of france with a pajero is asking in their forums if there are accessories for asian look
hahahahahah lol
mga sir, macngit lng po.. bk pwede nyo k 2lungan kng ano cra ng pjero k abt s preno kc lumulubog n sya. repiar kit kya o buong hydrovac n? tnx
Bleed mo muna. Baka may air.
ay, onga pala. but if problem presists even after multiple bleeding, replace na yan.
may pajero dito sa amin na galing sa Belgian embassy gen2. the two tone lower part is darker, bumpers same color as the cladding, black grille, black tail light bezel, balck door handles, black side mirror, tail/turn lamps on the rear bumper, mags looks the same but rough finish, rear plate plastic, front plate plastic, and others pa.
it has a 2.8tdic engine, abs and other good stuff. a good alternative to a gen2.5 I like the gen2's body better.
thanks for the replies guys,anyway,do you guys have any idea how much the tail/turn lamps on the rear bumper cost?do you have to replace the whole rear bumper?or you can just drill the existing bumper?thanks
ok,thanks sir,anyway,would you know kung saan po available yun depo na tail/turn lamps?i tried calling some shops who sells depo products,pero wala po silang stock eh,thanksOriginally Posted by ARB
post ko later, galing lang me sa autobuff store sa banawe n retiro. i got my depot euro tail lights doon. they also have the bumper signal lights there. got their calling card kahapon.
nikko m,
i suggest you have the drilling of the bumper at professionally. hirap na magkamali. bubutas kasi yan.
kcboy,
sir,how much po yun tail/turn lamps and tail lights na depo?thanks
alam ko last time matatawaran mo yung euro tail lights at 4,000. yung bumper signal lights mga 3,000. pair no po yun. try mo tumawad pa if you plan to get both at the same time. malay mo bumigay ng 6 to 6,500.post ko mamaya. nasa pajero ko pa yung card.....tamad pa lumabas sa parking lot ako.
ok,thanks sir,when i go back to manila,ill definitely get those lamps,and one more question,nakita ko pa kce sa pic yun euro tail lights,iba yun color ng lens nya,its smoke,clear and red right?yun smoke ba yun anf equevalent sa amber as signal/turning lights sa orig tail lights?Originally Posted by KCboy
