Results 1 to 4 of 4
- 26
June 30th, 2003 05:23 PM #1To Delica/similar van Owners:
I plan to set up the family school bus and replace the factory music. I started replacing the 2 din japan stereo with a stock CD/Cassette HU from a sport trac. Fits like a glove. Sound improvement almost 100%. Next replace the papercone factory speakers
Anyone know the size of the rear factory speakers? For sure the fronts are 4 inchers
Also need advice on the ideal size of subwoofers and sub placement (just need a single one for added boom-boom, nothing at SPL levels).
Worst case I plan to get those amplified tubes (mount them right behind the front seats) or those amplified daichi stealth subs (under the rear seat)
Final placement question: In similar vans, where does the amp usually go? (the rear cargo area is sometimes used for well, cargo) So suggestions for an unobtrusive location for amps and sub box is appreciated.
BTW, I have a 7 seater with revolving captains seats in the middle/ folding rear bench.
Again, Anyone know the size of the rear factory speakers?
Comments are appreciated as usual. Daghang salamat
Mac
Tynee thanks for the heads up. I will visit you soon.
June 30th, 2003 10:36 PM #2
Same size din ata siya as Hyundai Grace speakers. Ang problema, hindi ko alam yung size dahil wala yung Grace dito. Nasa Baguio. hehehe.
I put an almost 1 cu ft sealed enclosure for my 10" subs behind the third row seats sa may luggage area. The box is constructed out of MDF and a grille protects the sub kaya pwede pa din ako magpatong ng gamit sa sub box. The amp is also screwed on the said box.
You can hang the amp from underneath the last row of seats. Just make sure you have enough extra wire to take into account the folding and other adjustments the seat might have. I hung a 12 disc CD changer and a Nokia trunk phone under the seats in my Besta using wire ties. Wala naman naging problema.
- 26
July 1st, 2003 08:52 PM #3Thank you very much otep. You have provided helpful insights.
Follow up:
Bolting the amp to the sub box would be perfect pero wont it affect the acoustic qualities of the box? Paano kung ma butas/mag crack/bumigay?
Placing the amps under the rear folding seats is also a very good option that i will consider.
Now last remaining puzzle is the exact size of the rear speakers
Thanks Otep.
July 1st, 2003 09:14 PM #4
Ser Big Mac,
Makapal yung MDF na ginamit ni GlennSter for my box. Screws pala yung ginamit to hold the amps at hindi bolts. hehehe. So don't worry about losing the airtight properties (assuming sealed type enclosure).
Daming issue ng SU7:grin:
Xiaomi E-Car
