Page 5 of 13 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 281
    Mar 2003
    Pajerokid
    ano yung parang airfilter na maliit na nakakabit sa engine mo? ano purpose nun at malaki ba power gains?
    Mar 2003
    Sir otep
    gaano ba dapat kalayo ang average na tinatakbo ng diesel bago ma overhaul? sige try ko gawin yung washer na upgrade bukas, para lumakas pa ang hatak, aside from washer ano pa ba pwede gawin para bumilis? nakita ko sa pic ng engine ni pajerokid merong maliit na airfilter ok ba yun?
    PROMDIBOY,
    Depende iyan. Yung kay Pajerokid maaga niya napa-overhaul. Anyways, can afford naman siya. Right, Arman?
    Most diesels run into the 100K's before mangailangan ng overhaul.
    PROMDIBOY,
    The small air filter you see is a Breather Filter, yung exhaust gases that come from your cylinder head evaporated oil goes to your intake manifold, ibes na pumasok ulit sa engine nilalabas nalang nito sa atmosphere.
    If you want to gain more horspower try installing larger exhaust pipes and a free flow muffler, you can also install an open type filter like K&N for more breathing.
    Apr 2008
    Quote Originally Posted by Yellow View Post
    PROMDIBOY,
    how much po kaya would it cost??
    1. free muff exhaust
    2. larger exhaust pipes
    3. K & n filter open type + breather
    any shops you recommend na posible n sila n gumawa nito.... est naman po inc labor....
    nweiz.... i came up with some site na they used bleeder valve instead.... pero on my opinion.... mdyo matrabahu kc trial and error ang pag set.. unlike with the wash modz.... set n tlga ang bukas ng actuator......
    hi guys, newbie here. i just want to share my experience with you guys, i have a 98 model space gear local version, after reading through these pages the last couple of days and after consulting with my trusty mechanic, this morning i installed three (3) washers on the actuator can mount, the 3 washers total 4.56 mm. me and my family went to church and after a 15km drive i opened the hood before going to church to check if any abnormalities would result. well, aside from a slightly hotter engine bay, there was nothing unusual. oh by the way dwhile driving along slex i noticed an increase in power, mas magaan ung takbo ng space gear ko.
    by the way, my mechanic told me not to use an air filter in the crank case hole where the hose was, sabi niya, instead of spending for the filter, just remove the connection of the hose to the filter and angle it downwards para tatapon na lang kung ano man ung lalabas na oil dun.
    finally, i also removed the small plastic tube that connects th air filter housing to the fender wall, mas nakakahinga ang engine, ramdam ko especially in low rpm situations.
    tanx for the inputs na nababasa dito.
    Aug 2003
    i still have the pictures that Pajerokid posted here, which shows the step by step procedure, words and pictures, of the whole thing. Applies to both 4d56 and 4m40 engines. I used these pictures to show to the mechanic when I did the same procedure on my pajero 4d56 tdic. its on microsoft word fomat.
    But to make it public, siguro we need to ask the permission of pajerokid before I can share it back to tsikot public?
    Nov 2007
    sir baka pede po pasend yung pictures sa smiley_646*yahoo.com. apply ko din po sa paj ko.
    Sep 2008
    Quote Originally Posted by shon View Post
    Tanong ko lang mga sirs if there is really some gains in doing this?
    won't the intake suck hot air radiating from the engine?
    Sep 2008
    sorry double post
    Sep 2008
    Mga sir, bump ko lang po, will removing the plastic tube that connects the air filter housing to the fender wall have any gains?
    TIA
    aw, ngaun ko lang to nakita
    this is a nice mod, lalo na it is almost costless.
    Quote Originally Posted by OTEP
    PROMDIBOY,
    NYEK! 8O Wag kang maingay Otep baka may maniwala sayo! :lol:
    Mar 2003
    SIR YELLOW
    PWEDE ANG LAGYAN NG OPEN TYPE KNN FILTER PAJERO DIESEL????
    SIR PAJEROKID
    INGAT KA PALA NAUUSO NANAMAN KIDNAP FOR RANSOM.
    Paano malalaman kung sobra na boost at walang boost gauge?:?:
    the engine will overheat if there is too much boost. and sometimes if it is too much you will also lose power.
    Nakakasira po ba ng makina ang sobrang boost? :|
    PROMDIBOY,
    Pwedeng pwede yung akin and kay pajero kid naka open type cone filter.
    Syempre. But we're still running a relatively mild boost increase so I'm not worrying so much.
    I think I will break my tranny (due to the off-road antics) first before I break my engine.
    Quote Originally Posted by PROMDIBOY
    SIR YELLOW
    SIR PAJEROKID
    im using an open type cone for the paj. Meron slight increase in power and mas responsive yung engine in general. By the way, SIMOTA lahat gamit ko..... proof na di ako rich kid hehehe :wink:
Cranking up the boost on the 4D56TDIC
