Results 31 to 40 of 249
- 52,731
August 13th, 2021 12:01 PM #31i'd go gasoline if not for the floods.
had i been driving my gasoline vehicle the other week,
malamang ay hindi nako naka-uwi that night.
if vehicle safety and anti-pollution were the government's objective,
they should set even higher standards for our public utility vehicles.
instead, they give them a free pass.
"license to pollute" and "license to endanger".Last edited by dr. d; August 13th, 2021 at 12:03 PM.
August 13th, 2021 12:14 PM #32
Old school diesel engines lang pwede mo ilusong sa baha. old school diesel does not have have the electricals commonly found on petrol engines. (you normally cut-off the air intake to turn off the engine). only issue you have to worry about is kung mabasa terminals ng starter.
Pero since modern diesels now have computer boxes, may limit na din yung lusong mo sa baha.
One more thing, diesel vs petrol sa baha. since the diesel engine is normally bigger than their petrol counterparts, you also get a higher pressure of smoke coming out of the muffler. hence, higher chance of success sa baha.
- Mar 2014
- 2,127
August 13th, 2021 12:36 PM #33Kung pollution lang naman dr., umm ewan ko lang. Alam naman kasi ng karamihan na matagal nang pinabayaan ang kalikasan ng pinas hanggang sa nasanay na ang mga noypi diyan. Pero kung titingnan niyo sa malaking larawan, bakit walang kuwenta daw ang ginagawang dolomite beach sa manila bay? Siguro anti-pollution yun kaso may mga nagrereklamo na sayang lang pera diba.
Ang punto ko lang, baka naman pag gumawa na sila ng hakbang para jan sa tinatawag na anti-pollution sa mga makina ng mga bagong modelo ay baka tuloy na kaliwa't-kanan na pagpuna nanaman ulet ang manggagaling sa mga mamamayan.
Anyway huwag na iyon tuloy na tatalakayin rito kase panget lang magiging patutunguan ng mga ganitong usapin. Kaya btt nalang po tayo.
- Mar 2014
- 2,127
August 13th, 2021 12:41 PM #34But ppvs and similar rugged suvs usually have advertised wading capacity of at least 700mm. I'm not so sure sa crossovers pero kung meron man, baka below 500mm lang. Although useful lang yan sa floody areas during rainy seasons. Yet it's one of the reasons why mas common sila rito than cuvs.
August 13th, 2021 12:48 PM #35
August 13th, 2021 12:58 PM #36
based on my personal experience.
it's basically how high is the starter from the ground (yes, i've burned a couple during college thanks to Espana)
for cars with a lot of electronics. you can also start to panic when the engine fan starts hitting the water as it will start to spray water all over the engine bay.
- Mar 2014
- 2,127
August 13th, 2021 01:18 PM #37Ya good points. But for diesels, usually puro common rail na talaga. Unless archaic model like the lc70 (tho crdi also na ata yung 1vd niya) or the former l300 with the mighty 4d56 engine kaya yes. They have become more vulnerable na than before but still fare better than petrols in this aspect.
- 52,731
August 13th, 2021 01:31 PM #38
August 13th, 2021 01:59 PM #39
Kung yung tubig baha is just half the height of your vehicle’s tires, then that would be just fine. Gas or diesel man yan sasakyan mo.
August 13th, 2021 04:11 PM #40
^agree, normally yung starter is a bit higher than the vehicle's floor
so only issue will be the fan
one more thing, college days, linagay ko yung air intake sa ilalim ng grill. big mistake
high idle RPM at engine start
