Results 1 to 17 of 17
    Dec 2017
    mga boss bumigay na bearing ng sliding door ko. ano size pang replace dito? ty po
    Dec 2017
    Quote Originally Posted by christian p View Post
    sa baba po yan na rail
    i would think it is the entire assembly that has to be replaced...
    but i could be wrong...
    good luck po.
    Dec 2017
    good luck po.
    thanks po. nag hanap na po ako sa mga auto parts wala talaga. mag cucostomise nlng po ako
    try the casa. it will probably be more expensive there, but it is better than nothing.
    Dec 2017
    ok po
    Dec 2017
    ok po
    sir do you have suggestions sa loose na column shifter
    Dec 2017
    Column shifter? Perhaps attaching a picture might help you to get help.
    Dec 2017
    Dec 2017
    bumabangga ang 3rd gear sa gauge
    Dec 2017
    So that is the column shifter! How silly of me not to know it.
    I don't know exactly how this "extending of gear shifting" happens but the usual remedy I have seen on jeepneys is to bend the rod.
    I think over time, the third gear will "automatically" disengage. I believe it has something to do with the "extending gear".
    Dec 2017
    ok po will try to bend thanks
    ...worn bushings?
    what i do not know, is...
    can the bushings be replaced, or do we have to replace the entire assembly?
    Dec 2017
    ...worn bushings?
    where are the bushings located sir?
    google for a diagram, po, to see how complicated things can get.
    "L300 column shift".
    unless you are a knowledgeable car owner, your better bet is probably a knowledgeable mechanic.
    i'd get a mechanic, myself...
    Jan 2008
    Nasa ilalim ng manibela.. sundan mo lang yung column shifter.. malamang may rubber bushing yan na maluwag na.. wag mo muna bend yung shifter
    Dec 2017
    ok mga sirs salamat po
l300 versa van sliding door
