Yup! Though it has two separate bulbs.
Re: the led bulb for the drl. It's a p13w type bulb for the drl. Was also planning to change it to led but cant find a local seller for it. Found something on amazon prob is it has higher wattage, recommended for the gls is only 13w per drivers manual.
Nice! How did you do it? I guess you change your turn signals to led then fog to hid?
I don't really have plans on charging the fog lights to white since it will have poor visibility on foggy or hard downpours.
Also retrofitting is a no no for me since it will be prone to moisture.
I prefer OEM PnP type bulb replacements.
Pasali po my TR3S...3 weeks old monty. Buhay OFW kaya miss ko na bonding moments namin. Bitin ang honeymoon period#MSCP033
Gudpm
New owner if gls variant. Ask ko lang if may tpms din ang gls. Also, need pa ba i-setup ang reverse camera?
Thanks
While drinking my coffee may nagpark na all new MS 2016, The more I look at the rear, the more I find it attractive.
Honestly biglang tingin ko dati I don't see that way, pero ngayon napapa-wow ako.
IMHO dahil hindi common ang design neto front or rear mas nagiging standout ang looks compare sa ibang all new.
Hopefully makapag-decide narin ako, December pa naman.
Sir ano yung yellow figures? 443 ft-lb and 233hp yan ba yung after the ecutek chips add on?
How much ba ang magpadyno? Curious lang para malaman ang stock whp and Torque![]()
Sir the dyno is accurate 178HP on paper, if you convert into PS 181 sya.
Power converter: bhp, PS and kW
Power converter: bhp, PS and kW - Driver tools - Driving your car - Which? Car
TGP, HP/RPM ang ginamit sa power
While sa brochure PS/RPM naman ang ginamit.
May nakapag try na ba mag lagay ng front prox sensors or camera sa new monts? I'm thinking of installing one, wala lang. Haha. Saka may hud upgrade ba na available sa winterpine?
Sino na ba may pinaka mataas ng distance travelled? :D
