Silver
Sent from my HUAWEI MT7-TL10 using Tapatalk
Sabi sa owners Manual, with or without DPF 5W30 ang oil...magkakaiba lang ng ACEA classification...
Eto vid n Steering issue ko...
https://youtu.be/Fe4Tz2sxvCk
https://youtu.be/2wAPYMrsea4
What todo, lagi busy daw Peaks Motors Manila Bay...
1. Complain to mmpc about peak motors manila bays and the sa who cannot give you a scheduled certain day for service. If they are busy. They should check their system which day pwede ka schedule. You bought an expensive vehicle worth 3x mirage. And the sa cant schedule? Ang bobo naman.
2. Probabaly sticking front caliper. Check even wear on the brake pads.
3. Or failed front right shock. Check for tiny leaks.
4. Or steering alignment.
Hinay hinay brad sa pagka fanboi. Constructive posts help.
Bakit ka naman magdadrive ng walang kamay bro? Please be noted na kung warranty issue kahit saang dealer pwede. Kung warranty issue ha. Hindi kasi si dealer may sagot niyan si Mitsubishi mismo.
Pwede claime sa Peakmotors Abad Santos or Union Motors in Balintawak. Iisa lang may ari ng mga yan.
*momo23 oo ser wag ka na mag Silver (para mas konti kakulay ko) hehe.
Normally sa warranty service wala kita/profit ang service center. Sa Pms service sila kumikita. Hence they push you off or they ask you to bring the issue during the pms(where no service/work order is generated in their system regarding any issue brought up)
To help you with the lemon law. Open a work/service order immediately regarding the issue. Mmpc requires them to address open work orders.
Obvious ata na sa service ako. Hahaha
*ser StockEngine, yep useful tip...nakita ko yun dun sa Warranty booklet. Sige will make use of it nga.
MODERATOR'S NOTE: Let's drop the fanboi jokes. Things might get out of hand again.
