If it's constantly lit up, it means you are in valet mode ... which means the security alarm will not be activated ...
Hi guys!
Just got my GLS PR 2017 yesterday sa Union Motors Corp.
Tanong ko lang po kung magkano usually payment sa LABOR FEE kapag magp-PMS na?
Sa Pampanga pa kasi ako and iniisip ko kung worth it ba pumunta pa sa Manila for the free labor and oil filter.
May PMS+ din ako.
Thanks in advance!![]()
Yung sakin po constantly naka on lang ang blue light, not blinking. So meaning dis-engaged/disarmed yung alarm?
Kahit ilock ko via key remote, constant on pa rin. Ni-try ko buksan ang locked doors/ aluglugin ang sasakyan, di nag aalarm.
May ibang paraan po ba pag enable? O sira po ba alarm ng unit ko? O talagang walang alarm ang base model (GLX)?
Note na basic lock/unlock remote lang meron ako, no keyfob/keyless entry, no pushbutton start.
Find the alarm button under the dash, normally it's red color and usually on the left side of the steering column ... turn on your vehicle (but do not start) ... press the button for a couple of seconds until the light goes off ...
Good thing I read this thread. I have the same situation. I asked may SA today about that blue light and adviced mo to locked all the doors and start the engine and look for that red button. I asked him twice are you sure I should start the engine? he said yes sir........![]()
I just learned something from my unit (gls entry model automatic)
I just find it weird that my DRLs are the foglights?! ... start the engine, fog lights open... I cant turn them off!... the only way to turn them off is to turn on the park lights... but if I do that, all park lights (including rear) will turn on.
Its a small issue, but most people outside think I have left them open...
Has anyone remedied this... I want the DRLs off but I still want my fog light to be functional (as foglights)
end of the day, happy with the car ;-)
Does anyone here na nagpakabit kay sir gary - hid retrofit? pricing? TIA
I followed the instructions stated. I set it to on, and I pressed the red button that sticks out beyond the other things under the dashboard. I even tried pressing it for 10+ seconds. However, the blue indicator for the alarm still stays lit continuously. Is there something I am doing wrong / forgot to do? This is for a 2017 GLS Premium, by the way. Thanks in advance
make sure you turned on your ignition switch, you will know its on if you see all the instrument icon lighted. It also happened to me.
Key positions are Off -> Acc -> On -> Start ... set it to ON and not Acc ...
For Push Button Start systems ... press twice without stepping on the brake pedal ... light should turn green ... amber light is Acc mode ...
Yes, I did set it to ON (without starting the engine). The push button light is green, and the instrument cluster is lit up.
How long should I press the red button? Nothing still happens even after 10+ seconds of pressing it continuously...
All the information manual says is bring it to the casa in such instances.
Nakabukas ba pinto ng tinry mo itong sequence?
Sent from my MI 5s using Tsikot Forums mobile app
Ganyan din kasi s kin dati ayaw mag on. Ganun lang din ginawa ko. Bukas pinto double tap s start button tapos press ng matagal s alarm button hangang mag chirp ng dalawa. Pag di pa din gumana e pa check n s casa o winterpine.
