Page 208 of 210 FirstFirst ... 108158198204205206207208209210 LastLast
Results 4,141 to 4,160 of 7539
    Thanks mga boss, check ko ung hose and noozle.
    Sent from my SM-G920I using Tapatalk
    Jul 2017
    Quote Originally Posted by bongliza View Post
    After checking no problem with hose, nozzle, and confirm you have enough washer fluid. Try to switch on again a bit longer (longer switch on 2- 3x). It take few sec to fill the hose to the rear compared to the front.
    Mar 2004
    Avoid running the washer motor too long ... might burn out ...
    Jul 2017
    Quote Originally Posted by DAD525 View Post
    BTW, I mean turning on of switch a bit longer is only around 3- 4sec per turn on. I did in my unit for around 2-3 times before
    the fluid comes out from the read nozzle. Sa front windshield we do switch on about a sec only and we see the fluid right away
    spray on the front windshield.
    Walter thanks for that comment..
    Jul 2017
    BTW, only did during the first time I noticed that also no fulid coming at the rear (short switch on/twist on). After that, its
    almost same with the front windshield . Maybe the hose going to the already filled of fluid.
    Thanks, will try that sir.
    Dec 2014
    Using a Montero Sport 2018 GLS driving 2 hrs daily within the city.
    After 1 year and 1 month, I felt that the starting power was weak.
    How was the experience before the original OEM battery has to be replaced?
    I had No modifications done except a) DashCam; b) Disconnected DRL plugs and
    c) Replaced OEM Fog Lamp with same wattage LED.
    Thanks.
    Quote Originally Posted by valjean521 View Post
    Thanks.
    first things first.
    have your battery checked, po.
    your car may be a year old in your garage.
    but we have no idea of how many months that battery languished, slowly deteriorating, inside the car, before you brought it home.
    it could also be poor or loose electrical connections involving the battery, the alternator... it might also be a mal-functioning alternator... all resulting in impaired battery charging.
    refer to your list of warranties. they vary from component to component of the car.
    while casa can do the checking, i personally find their service snail-pacing. i bring my car to the battery shop, where i usually have my answer in a few minutes, and the proposed solution being much cheaper than the casa's.
    Jul 2017
    Thanks.
    I hope your battery still okay. Is it the OEM battery is not maintenance free type? Bring to the battery shop or gas station service to check. Maybe just need to top up battery fluid/distilled water.
    My unit is 2017 gls and OEM battery still good for about 2.5 yrs. Still register 14v on the display when engines runs, and 13.8v when off using a multi tester.
    Most likely badge lang. Pajero Sport are mostly RHD.
    Jun 2015
    Sit in front passenger seat, lock the driver's door (all doors will lock), unlock and open front passenger door (other doors will not unlock). Get out. Lock passenger door with the metal key.
    Sent from my Nokia 6.1 using Tapatalk
    Dec 2016
    Hello, napapalitan ba ito? Any idea saan and how much ang aabutin? Dami na kasi stains na ayaw matanggal. 20200601_095519.jpg
    Sent from my SM-N970F using Tsikot Forums mobile app
    Mga paps, sino sa inyo nagpalit na ng shock absorber? Anong magandang shock para sa monty natin? Thanks mga paps...
    Apr 2012
    Quote Originally Posted by junec View Post
    baka may hilig ka sa DIY, pwede mong gayahin ang video ng isang ka-monty at linisan na lang
    Paano Linisin ang Center Console ng Montero Sports | Paano Magpalit ng Slider at Shifter Knob | DIY - YouTube
    hindi pa ako nagpalit pero check out KYB brand, parang stock lang din. if you want an adjustable type na pwede mo i-vary kung firmer or softer ang ride, yung Rancho. others na gusto yung pang offroad go with brands like iron man, ridemax, old man emu and others. check fb page ng blueline car accessories, marami silang installations ng suspensions which may help in your purchase decision
    Aug 2009
    Good day!
    balak ko mag DIY palit ng rear brake pads. Ask ko lang kung kailangan ko din bang i-adjust yung parking brakes or salpak lang ng new brake pads?
    electronic parking brake din pala ito kaya iniisip ko baka kumplikado. salamat
    Sent from my ONEPLUS A6013 using Tsikot Forums mobile app
    Quote Originally Posted by bogart26 View Post
    Good day!
    don't change pads until the brake squeals. what you can do is lubricate that brake caliper and measure the brake pads thickness. how many kilometers na? wear a good mask, that brake dust is extra fine. EPB is maintenance free.
    Aug 2009
    43,000 kms na. pinasilip ko kasi sa kilala kong mitsu mechanic at malapit na daw mapudpod yung sa rear. observation ko eh minsan lang mag squeal. salamat
    brake pads can have premature wear if its sticking because the caliper pins aren't sliding freely. you can YT caliper guide pin grease.
    Aug 2020
    Mga sirs, is this price okay? Also are these kinda deals riddled with caveats? Sobrang sulit even tho its a 2018. Thanks!
    Aug 2020
    Good day mga sir
    patulong namn po
    may gusto kasi akong bilhin
    Monte na second hand 2017 pero acquired 2019, gls 4x2 at, 18k mileage plang
    makinis. may installed mods na. fenders/headunit/horns/mags/spoilers/rear and dash cam/
    in short porma ng itsura.
    sa mga used cars ng Monte 2018-2019, usually ang price is 1.1-1.2M
    malaki po ba ang difference sa features if bumili ako ng 2017 compared to a 2018/2019 variant?
    wala kasi ako makita comparison sa specs nilang dalawa.
    di ko kaya ang monte 2020, 1,6M. nashort ang cash ko hahaha
2016 Mitsubishi Montero
